20 Most Recent LG WM-2432H Front Load Washer Questions & Answers
Loud noise when washing machine is spinning
The loud noise could be caused by something stuck in the washer. Check the washer for signs of loose objects. It can also be caused by a worn-out belt.
4/6/2011 2:56:15 AM • LG WM-2432H... • Answered on Apr 06, 2011
Trying to do a standard wash -- washer does not
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
8/18/2010 3:00:32 AM • LG WM-2432H... • Answered on Aug 18, 2010
The door you can hear locks but noting else
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
11/30/2009 6:03:41 PM • LG WM-2432H... • Answered on Nov 30, 2009
Drum won't spin
Replace the motor sensor 1st to see if that will take care of it.  If not, then the motor may have a problem.
4/28/2008 11:41:52 AM • LG WM-2432H... • Answered on Apr 28, 2008
3answers
Water continues filling and overflows
Tubing at bottom of tub was loose and leaking, reinstalled it and installed a clamp and it works
3/25/2008 4:00:16 PM • LG WM-2432H... • Answered on Mar 25, 2008
Wm1832cw
Plug off the wall, check your washer plug, & the wire leading to the machine; there shd be some loose connection somewhere, your wall socket.........
12/2/2007 1:43:37 PM • LG WM-2432H... • Answered on Dec 02, 2007
Machine doesnt start. the wash and spin indicator lights blink alternating
first try unplugging and waiting a minute and then plug in and see if that resets it. if it does not try unplugging, wait a minute, hold power button in for 15 secs and then plug back in and see if that resets it. and finally, try the second one and continue to hold power button in while plugging back in. all are different ways of resetting some washer models. one might work for you and cannot hurt to try. good luck
11/20/2022 7:26:11 PM • LG WM Washing... • Answered on Nov 20, 2022
2answers
LG Fuzzy Logic 8.2 kg top louder WF-8071TTP
This dE error or fault code to indicate that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
10/29/2018 1:31:58 PM • LG WM Washing... • Answered on Oct 29, 2018
LG error code
its best to get an engineer to the problem as it could be anything at all or just an alignment problem eric
12/27/2017 6:08:54 PM • LG WM Washing... • Answered on Dec 27, 2017
Indesit WM12X the wash program starts then freezes (The dial doesn't turn)
Sounds like the dial timer is defective, I am not affiliated with this site, https://www.repairclinic.com/Video
4/25/2017 4:31:21 AM • LG WM Washing... • Answered on Apr 25, 2017
LG washing machine Model No: WTH9556 manual
http://www.lg.com/au/support/support-product/lg-WT-H9556
3/29/2017 4:12:09 AM • LG WM Washing... • Answered on Mar 29, 2017
Why is my lg wd 1049c frnt loader washing machine leaking from the lh top cnr between the top drawer panel and the main body panel every time the machine fills, i have checked the powder drawer and th
Remove the screws that attach the top panel at the back of the machine, slide the top backwards and remove the top panel. Run the machine as per normal, but be careful as the electrics will now be exposed, you will be able to see where the water is leaking from and be able to repair/replace defective part.
8/15/2016 1:24:03 PM • LG WM Washing... • Answered on Aug 15, 2016
Lg washing machine-wt1501c
If you wish to get some details; check the site linked here. Pull up older posts........ http://electro-medical.blogspot.com/
6/12/2016 7:02:11 PM • LG WM Washing... • Answered on Jun 12, 2016
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off see if the water pump making that noise or is broken should look something like this one 26197828-pe3l0ypp1vfpknq0mkt0qwu4-3-0.jpg
5/18/2016 9:54:37 AM • LG WM Washing... • Answered on May 18, 2016
LG WM-2432H Front Load Washer Logo
Popular Tags
12 questions posted
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
WM LG
  • WM LG
Most Popular Question
door hear locks but noting else
  • Washing Machines
