20 Most Recent
LG WM2077CW Laundry XL Front Load Stackable Washer Questions & Answers
Lg wd-1438rd wont turn on
It sounds like when you moved the machine it pulled a plug off inside the machine, the only way to find out is to disconnect the power and remove the top of the machine, You will be able to see if anything is not connected as it should be.
Whats a good discount site for LG front load washing parts.
I used Encompass to order LG parts at http://www.encompassparts.com/ . LG Canada does not provide parts directly to consumers, and therefore had to order from Encompass in the US on several occasions. I am not sure if they are best from a discount perspective, but they are very helpful, and I have not had any problems with their service or parts.
No power to the lg washing machine
This is a hard problem to diagnose remotely. Someone has to have a look at the machine, as any number of electrical/electronic failures could cause a loud popping noise. I would recommend a service call.
My lg front load washer will not turn on when i
Had the same problem today. On the front bottom left hand side there is a small door. Open the door and unplug the black rubber hose, this will allow the water to drain (make sure you have a small bucket to drain the water into.) After the water has drained, unscrew the black filter. Wash the filter and insert it back into the washer. Turn the filter until it will not turn any further. Plug the black water hose and close the door. If you had the same problem I did then it should work.
LG recommends that the filter be cleaned twice a month.
LG WD-1438RD washer dryer combo won't turn on
Okay well i had the same problem with my LG WD-1438RD so i took it a part it was a loose wire in the display module easy fixed. I guess from banging the door closed and hitting the buttons to hard made it come loose. To fix it all you need is a phillips head take the two screws out of the back up the top then slide the lid forward. then remove the powder tray thing unscrew the 2 screws behind it push the clips out of the way just be careful not to break em. re connect the wires! job done =) i put glue and electrical tape on the wires and plug so it shouldnt happen again..... I hope i helped you good luck
My LG washer won't turn
replace the main control unit under the inits top cover in the left rear top corner & inside the plastic cover if when you open the cover that protects the mainboard from water spray(if theres NO RED LED lit on the control board) then its the board that needs replacing,if it has the LED lit then run the diagnostics per the tech sheet located inside the machine and it will tell you whats actually wrong,next step is to replace the touch pad located around the selector knob on the front face of the unit
