Dell 1720dn Laser Printer Logo
Posted on Jul 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper Jammed totally removed but indicator still records paper jammed
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Aug 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
2303
Points
6
Here is a very key fix to the problem described:
The 2 rollers which help feed paper get slippery and don't work well after a while. These rollers are found by flipping the unit over (after removal of the toner/drum/paper drawers) and exposing them (they are towards the front of the unit). The two rollers have one rubber band each which provide friction. Just remover the rubber bands (black), flip them "inside out" and replace on the unit. This will expose a new surface, an viola!... virtually double the life of the roller... The other option is to obtain a roller replacement unit from DELL/LEXMARK. They are aware of the problem and have a "kit" to service the unit. Good Luck!....
Joseph Vernice
Level 2:
New Friend:
  • Expert 63 Answers
  • Posted on Jul 28, 2009
Joseph Vernice
Expert
Level 2:
New Friend:
Answers
63
Questions
0
Helped
27907
Points
221
Open the panel at the rear of the printer. I'll bet you find more paper back there. It happens to me all the time.
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
1helpful
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
MESSAGE : RECORDING PAPER JAM
Dear
The paper jam is a common problem, you need not to replace to ink cart.
Check the plain paper inserted properly or there is no paper inside, Put power OFF and ON. Also some model needs to press OK or START key to remove the paper jam message after removing the jammed paper.
Thanks.
Message reads:-Paper is jammed in the product. Turn off the product, open the scanner unit, and remove the paper. See documentation.' I have checked for any paper jammed, but finds none. I have even u
Did you try unplugging the power cord and waiting a couple of minutes, then plug back in and see if the printer resets itself. Also try checking all the paths that the paper travels through the machine for any scraps of paper that may have torn off during the jam up. Sometimes a very small scrap will prevent printers from resetting themselves. Also disconnect the printer from the computer before unplugging so the printer doesn't receive any signal from the computer. It may not mean anything.
1helpful
How to clear error code 13.20.00 on CP3525dn
Error 13.20 indicating paper jammed.> check any paper jammed inside? remove it...observe the diagram of paper path & sensors where possibilities for paper jamming..
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
1helpful
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Printer is totally jammed
check whether any paper is jammed you can remove the jammed paper from the back of the printer .there is a assess door which can be easily removed and from there you can check if there is any paper jam and you can remove.if there is no paper jam and you still face the problem.it is necessary to open the printer and service the parts and oil the gears to make the printer move fluently.you can do it your self if you have proper screw driver it does not require any thing execpt a proper screw driver to disassemble the printer.or you can take it to any proper service center and it will work properly after it is serviced.
2answers
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
