SOURCE: Panasonic Kx-t7456 digital super hybrid system time setting question!
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
SOURCE: Change the time on phone system
1) press "Program", then * *, then 1234,
2) press "0 0 0",
3) press "speaker" two times,
4) change the time
5) press "store".
6) pick up the receiver to complete the change.
Do this change on the "lead" phone and it will reset all the others on your system. Not exactly an intuitive process to be sure!
SOURCE: voice mail greeting
Sign in to mailbox 999 and 998 and poke around. You should find some greetings in there. Else, if you have the installer software you can go in from that and make the changes.
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
