20 Most Recent
Panasonic KX-T7636-B Corded Phone Questions & Answers
How do you set up
1. Raise the handset on any telephone in the Panasonic Telephone system.
2. Press the "INTERCOM" button and dial 165.
3. When answered by the Auto Attendant, dial # XXXXX * 9 9 8.
(Pound Six Star Nine Nine Eight)
4. Enter the Administrator Password. Followed by a #. (Pound) If required.
5. Dial 5 to "Modify Message"
6. Dial 1 to "To Change The Company Greeting"
7. Enter the Company Greeting Number from 1 to 32.
If you are not sure of which Company Greeting Number to change, then start with 1.
The Panasonic Voice Mail system will actually play the greeting to you.
Then you can determine if it is the correct one you want to change.
If it isn't, you can dial 2 and move on to next greeting and so on.
If you select a greeting number where there is no greeting recorded,
the Panasonic Voice Mail system will prompt you to record one at that time.
You may dial *1 (STAR ONE) to skip recording and return to Step 7.
8. When you have found the Company Greeting you want to re-record
follow the system prompts to record and save your new greeting.
Note:
You can change the Company Greetings remotely from anywhere.
1. Call the main number of your business.
2. When answered go to Step 3 and follow the same procedures.
3. When completed....Hang up....
10/9/2015 3:25:34 PM •
Panasonic...
Answered
on Oct 09, 2015
How do I rename Extensions?
Press program **1234
use up down volume keys to find extension hame
selct ext. number
enter new name
store
these changes dan only be made from a 3 line display phone
6/1/2014 5:22:42 PM •
Panasonic...
Answered
on Jun 01, 2014
I have a Panasonic KX-T7636 phone system. We have
You have a Panasonic 7636 PHONE. The system is either a TDA/TDE or NCP. The Voice Mail system is either embedded or a TVA and it comes with a set of instructions. Custom service announcements and company greetings are administered from the message manager's mailbox 998. Check your original installation notes and documentation for how to do that.
Carl
7/9/2011 6:58:42 PM •
Panasonic...
Answered
on Jul 09, 2011
Panasonic KX-T7636
I transfer calls from
There is and you found it. It's adjustable, depending on your system. In a TDA-30/50 it's system program 473 and the keyword search is either Extension - CO or Call Limit. If turned on, the default is 10 minutes...it's adjustable to 60 minutes.
Carl
7/6/2011 12:41:40 PM •
Panasonic...
Answered
on Jul 06, 2011
