I replaced the black cartridge with a new one. I only need to print black forms today and don't have any color catridges available to me at the moment. I figure a new color cartridge can wait until tomorrow. Now I get error 1203 and can't print. I've gone through the manual and performed all the steps for error 1203 numerous times with no success.
Any ideas of what I need to do to solve my problem?
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
The 1203 error indicates either a communication problem between your cartridges and your printer or a short in one of the cartridges. Please follow the steps below to identify and fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier
moves and stops at the loading position, unless the All-in-One is busy.
Note:
If the carrier does not automatically move to the center, turn off the
printer/unplug the printer from the power source and then slide the carrier to
the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer.
Pull out the power supply, black box where the power cord is plugged in at the
back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge
first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. Then try to print a document again to verify that the problem is fixed.
