20 Most Recent Lexmark X7170 All-In-One InkJet Printer Questions & Answers
0answers
My lexmak x7170 does not
Is your printer even powering on? Try to remove the power adapter from the printer(small black box behind the printer where the power cord is attached).
Before reinserting the power adapter, check if it's warm or cold. It could be a defective power adapter issue. Wait at least 10 seconds before replugging the power adapter. That should give enough time for your printer to reset itself.
Check if your printer is functioning now.
2/2/2017 10:52:51 AM • Lexmark X7170... • Answered on Feb 02, 2017
2answers
Brother MFC-9320CW is printing blurred images
Click menu once and OK 3 times and reply the status of the test print
1/19/2016 8:33:43 AM • Lexmark X7170... • Answered on Jan 19, 2016
2answers
How do I stop my Lexmark printer from prompting me
See link on Lexmark Support site.. This issue requires a software patch easily downloaded from their technical support site.
Here's the link:
http://support.lexmark.com/index?page=content&id=SO4168&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=&searchid=1287063627491
1/15/2016 12:12:21 PM • Lexmark X7170... • Answered on Jan 15, 2016
2answers
When i try to fax
The 2200 error indicates that the scanner has stalled. Refer to this article 2200 Error on the Lexmark X7100 Series All-In-One to clear the error message and resolve the issue.
6/4/2015 6:19:29 PM • Lexmark X7170... • Answered on Jun 04, 2015
Machine will not print nor copy documents....
http://support.lexmark.com/index?page=content&id=SO3533&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_X7170&searchid=1279293699902
error code 2200 is a paper jam. How about blank sheet caused by the printer ink cartridges still having the clear tape on the heads?
1/28/2015 7:56:10 PM • Lexmark X7170... • Answered on Jan 28, 2015
0answers
Cover open
Be the first to answer 5/22/2014 3:20:08 AM • Lexmark X7170... • Posted on May 22, 2014Be the first to answer
Download disc to connect to my laptop
go to the lexmark website and download the driver for it
2/6/2014 12:23:36 AM • Lexmark X7170... • Answered on Feb 06, 2014
0answers
Scan has gray on whole page
The scanner may be set too dark that an unprinted white page may show up light gray.
4/5/2013 4:13:03 PM • Lexmark X7170... • Answered on Apr 05, 2013
I have put in a new color cartridge and I am
remove the colur cartridge and check out that .did you removed the blue tape from its bottom or not,if yes.than its ok.
next option.remove both the cartridges from the printer.now take a dry tissue paper and isoprophyll alcholol liquid also called spirit.this is easily available at medical shops.with the help of both tissue and isoprophyll.clean the brown colur dotted circuit of both colour and black cartridges.the same bron colour dotted circuit is also in the printer exactly at the opposite side where the cartridge is installed.clean that both printers and cartridges circuit,
-------------- THEN , without inserting the cartridges.turn the printer off.from the back of the printer remove the power cord wire and the usb wire.make the printer completely unplugged .then wait for a minute.after that only connect the power cord wire.and on the printer.then ON the printer and insert the cartridges 1 by 1.insert it properly.then close the door and check out if the power button in the printer is blinking or not if its still blinking that means the cartridge is faulty.insert the old colour cartridge in the place of new and check out .and if the printer excepts the old colour cartridge that means the new cartridge is faulty so get it replaced but if the same problem in old colour too then its the problem of black cartridge too that also needs replacing.
this will help.
please do rate the solution.
thank you for using fixya,
keep updated.
thanks.
3/29/2013 2:18:53 PM • Lexmark X7170... • Answered on Mar 29, 2013
Lexmark X7170 All-In-One InkJet Printer Logo
377 questions posted
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
X Lexmark
  • X Lexmark
Most Popular Question
lexmark x7170 fax from vista when start
  • Office Equipment & Supplies
