SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
SOURCE: Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
sewman7
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
SOURCE: can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.
Cheers, Ginny
Ch
SOURCE: Needle hitting bobbin case and breaking off
It sounds like the machine is out of time.. However, it is not an easy fix at home.
