SOURCE: Dyson DC07 - broken 'Contact Head' release clip
Hi Wombat64
We noticed you are having difficulties with your Dyson vacuum cleaner. We think we can help, simply call our Customer service team for free on 0800 298 0298 between 7am - 10pm, 7 days a week.
We look forward to hearing from you.
Darran
Dyson Customer Service
SOURCE: Dyson DC07 keeps cutting out and smells of
does it smell like an electrical burning smell? sounds like your motor has went bad.
SOURCE: Dyson DC07 Vacuum Cleaner
It sounds like to me that you probably have a clog in the hose port, or that your attachment hose may have a hole in it. Both of these problems are common problems on the Dyson DC07 model.
The first place you should check is the clog part that's directly underneath of the hose. Pull this port out and see if you can see anything lodged inside the clog port:
If you aren't able to find the clog here, then pull the wand and hose out of the vacuum. With the vacuum cleaner off, pull the hose out as far as it goes, and inspect the entire hose assembly from the end that the wand connects into, until the end that fits into the vacuum itself. A lot of times this hose will tear due to the sharp end of the wand as the hose is being pushed back up the wand.
If neither of these solutions worked, please just use the clarification request form here on the Fixya repair page, and I'd be happy to do some more advanced diagnosing with you to figure this out.
If this was helpful to you, please help other Fixya users find this answer by rating the repair helpful, by clicking the thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris J.
GoVacuum
SOURCE: Sparking motor on Dyson assume motor brushes at fault?
A replacement motor can be purchased direct from Dyson via our Helpline on 0800 298 0298 at a cost of £36.31.
Alternatively we can arrange a service for £69 which includes parts, labour and VAT. This can also be arranged via our Helpline.
Kind regards
Darran
SOURCE: This is embarassing, but I have just looked at the
Hi the wand release button is located directly above the the Cylinder release button. The wand release button looks like the picture below. In order to releease the wand you must firstly make sure the Electrical cable is not wrapped up for storage. So unwrap the electrical cable. then find the item as in the picture. Press this button in and at the same time lift the wand. This will realease the wand from the spine of the Dyson.
