1, The Microline 390 printer prints very light or blank pages if the image drum cartridge or the toner cartridge is not installed properly. Re-install the image drum cartridge. Check the image drum contacts inside the printer.
2, If this step fails, then install a new toner cartridge. Bad connection between the printer and the image drum cartridge.
3, Check whether the toner cartridge is installed correctly. Re-install the edge and ensure that the sealed tape is removed from the bottom of the cartridge.
4, See to that the cartridge is seated correctly and the lock lever is pushed all the way forward.
For more printer related queries get in touch with our experts by just giving a call @ 1-866-293-9220.
Dot matrix printheads go bad, can be rebuilt, never had great luck cleaning, pins get stuck out.. Also there is a lever that moves the printhead closer or farther from paper. make sure that is in the right position. Usually on top cover may have numbers by the lever such as 1 , 2 , 3 etc
SOURCE: microline 420
When the alarm light is blinking what other lights are on. This is the fatal error code with the printer.
Remove the ribbon. if still not moving smoothly unit needs service. 3 year warranty on this unit brand new.
If you cannot move the carriage back and fourth accross,
there is a seriuois issue. unit requires service.
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
SOURCE: Oki Microline 520 printing slow
Re-seat your Printhead. If problem persists Replace the Main Board.
SOURCE: Microline 320 Turbo Print Quality Settings
You need to set it in Menu Mode -
Press MODE - the SEL light will go out. The menu light goes on. Press Group and the first line of the menu prints.
Gropu of related items keep pressing group until you see the print mode menu printed - once on the line press SET - keep until the printer prints the setting you want.
After you are finished press MODE to save the changes
