20 Most Recent OKI MICROLINE 320 Turbo Matrix Printer Questions & Answers
0answers
I have an oki microline 320 turbo printer at work.
Is this a networked printer? You may need to reload the print driver into your computers. Most printers are generic enough that computers will recognize them and automatically install the drivers. Sometimes you need to go to the manufacturer's website and download the drivers you need.
11/16/2017 10:33:45 PM • OKI MICROLINE... • Answered on Nov 16, 2017
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
8/8/2017 10:05:07 AM • OKI MICROLINE... • Answered on Aug 08, 2017
I use a power inverter to power my printer and the
Well it sounds like the old inverter had a problem with regulation and it has inturn blown the power supplies in both printers. Without buying new PSU's there is nothing you can do. The Switch-mode power supplies in most printers do not like unstable input and that is what your inverter gave them.
8/7/2017 5:42:12 PM • OKI MICROLINE... • Answered on Aug 07, 2017
OKI ML320 Turbo - printed 100+ invoices fine in batches of 10. Got to the last 20 and it started printing the top portion of the form incorrectly and then continued to reprint the same 7 pages over a
Unplug the network cable and restart the printer. If it sits there doing nothing then the PC's job that you sent to it is the problem. If however the printer although unplugged from network starts printing again then yes the printer memory is messed up and you will need a new main pcb as you cant clear its memory as its integral with the board.
7/26/2017 7:12:55 AM • OKI MICROLINE... • Answered on Jul 26, 2017
2answers
Okidata 320 will not line
If you need oki data customer service number, then you can contact with us, okidata customer service 1866-877-0191 for online help. For further Info Click: https://goo.gl/Ltis3S slide1-ymukdlto0iojz4nd3se3t5yk-4-0_0.jpg
7/22/2017 7:10:21 AM • OKI MICROLINE... • Answered on Jul 22, 2017
2answers
Oki 320 turbo alarm light
check the mesage in your operating mannual
7/8/2017 12:06:03 AM • OKI MICROLINE... • Answered on Jul 08, 2017
Okidata Microline 320 turbo problem
Solved this problem by going into the bios and changing the port from ECP to EPP, and then uninstalling the ECP port in device manager and replacing it with a standard parallel port configuration, no problems since doing that.
3/24/2017 11:35:14 AM • OKI MICROLINE... • Answered on Mar 24, 2017
2answers
Microline 320 turbo jibberish
The only thing that coould cause it to malfunction like this is a defective main board. Replacing the machine would be recommended as the board is rather expensive.
ebay has quite a few under $100
http://cgi.ebay.com/OKIDATA-OKI-Microline-320-Turbo-9-Pin-Printer-Working_W0QQitemZ120363664792QQcmdZViewItemQQptZCOMP_Printers?hash=item120363664792&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
6/18/2016 2:57:17 PM • OKI MICROLINE... • Answered on Jun 18, 2016
2answers
Why won't it print?
need more info. is it hooked up usb or parallel? Are you printing from windows or like an AS400 or OS X. What error is the alarm light blinking or just stays on?.
6/18/2016 2:51:37 PM • OKI MICROLINE... • Answered on Jun 18, 2016
Oki microline 320 printer labels are catching on plastic shield of ribbon. any recommendations?
Remove the plastic shield on the ribbon, you may get a bit of ribbon rub, but it's normally not noticeable.
12/28/2015 2:56:25 PM • OKI MICROLINE... • Answered on Dec 28, 2015
I find that we have to change our ribbons very quickly. perhaps a print quality setting needs changing....
Its more likely that the problem is cheap ribbons or old ribbons as they dry out with age.
6/4/2015 8:56:20 AM • OKI MICROLINE... • Answered on Jun 04, 2015
Documents wont feed
If not using track feed paper this printer should have a setting for paper height. If its set too high the
rollers wont grab the paper. Also look for any paper that might be jammed or caught up in any of
the roller mechanics.
3/15/2015 5:50:13 AM • OKI MICROLINE... • Answered on Mar 15, 2015
My dot matrix printer won't stop printing when it runs out of labels
Sounds like the media detect sensor is jammed or broken. Remove the platen and check underneath to make sure a label has become stuck over the sensor which would trick the printer into thinking it always has media.
11/12/2014 12:21:43 AM • OKI MICROLINE... • Answered on Nov 12, 2014
2answers
MICRO 320 TURBO PRINTS JIBBERISH INSTEAD OF INVOICE
Check your printer driver and the communication cable. These are the two most common causes of this issue.
10/6/2014 4:15:10 PM • OKI MICROLINE... • Answered on Oct 06, 2014
0answers
Driver
Be the first to answer 8/8/2014 3:01:44 AM • OKI MICROLINE... • Posted on Aug 08, 2014Be the first to answer
OKI MICROLINE 320 Turbo Matrix Printer Logo
374 questions posted
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
MICROLINE OKI
  • MICROLINE OKI
Most Popular Question
printer skipping
  • Office Equipment & Supplies
