Yadayada you told me to goole the model of my Proscan 7 and the reset factory i am french i don't understand what it means the words goole and query mixe me up
Thank you for all the quick respond really appreciate
have u removed your or previous owner google account off before you did a factory reset or have you tried hard reset but you need to take google account off first before u do it
It means you will likely have to do a "factory reset." That would return the tablet to "fresh out of the box" status. Yes, you lose what ever has happened since then.
1. Look for the reset hole on the sides of the device. 2. Poke the hole for 5 sec. using a paper clip or a pen. 3. The device will reset. If that did not worked try this. 1. Power off the device. 2. Press and Hold Volume down and Power button at the same time till you see the recovery screen. 3. Use volume down and select Wipe data/factory reset. 4. Press power button to accept. 5. Use Volume down and select YES. 6. Press power button to accept. 7. Press Power button to select Reboot after the reset.
Otherwise, you might have to take it to a shop or send it off and you won't like what that will cost if it is not under warranty.
you have to go into setting and set to manufactures settings. look for pin hole that states reset
now if you have a password already and you setup the password already that trying to bypass the password setting you will need the password in order to get to those setting i think.
you could go to website for the manufactures look up lost pass word bypass, or FAQ section, or if technical support can help you if you done all this already .
To perform a factory reset, you will need to do the following: -turn of the tablet -press the following and hold: power button reset hole -hold until you see android logo screen -poke the reset hole to navigate to `wipe data` or `factory reset` -select using the power button -select delete all user data -restart the device -choose restart/reboot after reset This procedure will delete all apps and data on your table
