It will not install the drivers or detect the printer
SOURCE: Driver printer all-in-one Canon PIXMA MP150 for Windows Vista(Dell)
Disconnect first your canon printer to the pc. if you have CD utility of the canon printer then insert it to the CD/DVD ROM and the install the the softwares. the system will be prompted you to attach the printer to the pc. and follow the on screen instruction..
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
SOURCE: Using the Canon PIXMA MP240 printer wirelessly
In order to do this, the laptops have to be able to communicate with each other wirelessly. I.e., you have to have a wireless network set up. If you do, then you are "printer sharing", using one laptop as the 'printer server' (with the printer connected to it) and the other as the 'client'. Step by step instructions are available at this link. Type "printer sharing" in the search box in the center of the screen and click on the Search button. Select the option that matches your requirements.
SOURCE: canon pixma ip1600 installation driver
http://software.canon-europe.com/products/0010230.asp click the link and in that select your operating system. and download the drivers for your printer.
SOURCE: Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
SOURCE: Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
