20 Most Recent
Dell Latitude E6410 Laptop Questions & Answers
How do I get my Dell De6410 to recognize external microphones
connected how, 3.5mm jack (mic port) or USB mic like mine
i can connect both
and then in the mixer sound windows
click on mic input I want
control panel
sound
recording tab , pick one./
if usb fails try all USB ports.
my usb mic real fancy with built in sound effects even echo and more.
there are like a gazillion types of mics now, boom mics and gee and endless list. even gun mics. to avoid noise , near by.
no mic told, at all
no OS told ,windows guessed
a usb mic also must show up in device manager or will fail
My battery light is staying on what does that indicate?
Battery light on indicates that your battery is charging. If charger if not connected and battery light is on, mean that something is not functoning correctly. If your charge is ok and battery keep charge level, leave it alone - just my opinon If you want to spend some good money, take it to a computer repair sevice
Wireless switch working
Dell E6410 (and others in that series) have a wifi slider switch on the right side of the laptop above the audio input/output jacks. When it shows red it's off.
Other Latitudes have the switch in a different place, like in front on the left or on the left side.
For any of them there should be an antenna looking symbol on or next to it.
My dell laptop wont start up and it wont go into safe mode
It could be your hard drive. If you have important data on the laptop HD you might be able to recover it by using another PC that is working and the getting a USB enclosure for the laptop HD. Then connect the old HD to the working PC via USB and copy off your data.
Before all that can you access the BIOS?
