SOURCE: ricoh service code 502 - 520 - 496
You need to reset the bottle code. Clear/modes, 1,0,7, press and hold clear button. enter copy sp. select drum(#2) scroll to 2972, enter 0 and press # key. Do the same for 2973. exit all the way out, and recycle power.
SOURCE: Ricoh 6513 error code PM CAll
Preventive maintenance.....
It's for a clean up, and sometime there's some parts to replace...
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
SOURCE: error codes SC548 ricoh mpc3500, how can you
The error means - Fusing unit rotation error.
Check if the fusing unit(right door{hot unit}) ,if it is rotating properly.
There could also be a sensor on the frame or the machine which senses the fusing unit rotation,(the sensor sometimes comes off)(remove the fusing unit and check where the fusing unit is seated).
Also try cleaning the sensor with a blower or brush.
SOURCE: When copier is putting on , it displays " error
that is a fuser overheat code. You can try pressing clear all, then enter 107 and hold the stop button until you see the SP mode come on the machine, then as it is in that mode, shut the machine off and back on.
If that doesnt work. I would suggest replacing the fuser unit.
You would need thermistors, rolls, overheat thermostadts.
Individually they would cost more than replacing the fuser.
