It wont let me access the boot menu or setup without the password.
If you have forgotten your bios password on your Panasonic Cf-51, there is no need to worry. There are a few simple steps that you can follow in order to reset the password and regain access to your computer.
First, locate the RTCRST jumper on the motherboard. This is usually located near the CMOS battery. Once you have located the jumper, remove it and then replace it in the opposite position. This will reset the bios password.
Next, locate the power button on the front of the computer. Once you have located the power button, press and hold it for a few seconds. This will reset the power to the computer and will also clear the bios password.
I hope this helps!
SOURCE: need to reset or erase admin password
There are Linux password removal programs on the Internet. It is designed to remove passwords on NT, Win 2K and XP.
You copy the program to a CD and boot up from this CD. It allows you to reset or remove the users and administrator passwords.
Google search for these programs "password recover"
There is another solution.
You can reinstall windows and this will give you a clean computer and possibly better performance without the accumulated junk/rubbish.
Don't forget to get/download all the device drivers (eg. video, audio, modem,NIC etc.) before you start.
SOURCE: unable to reset bios password
You will need to physically look at the motherboard, and next to the battery there will be a jumper and it will be on 2 of 3 available pins. Move the jumper to the other two and leave it for about 30 seconds. Replace it to the original two pins and then turn on the computer and enter BIOS as normal. Password should have been removed.
SOURCE: how to reset screen name password to my panasonic
if your suggesting user password in windows
here you go
http://www.youtube.com/results?search_query=changing+windows+password&aq=f
