I tried every driver that is available but noting seems to work.
SOURCE: No PPD available for mac
I used the Gutenprint driver for the Ricoh 220. It seems to be working fine.
SOURCE: Ricoh Aficio SP-C210SF
driver mismatch don't use the postscript driver unless you have the option installed as an option
SOURCE: ricoh aficio cl7300 error sc542 what does it and
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
the reset should be all you need...
reset link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: Hi I have an Ricoh aficio CL7300 printer and it is
sc 541=Heating roller thermistor error (Fusing unit).
The thermistors could be dirty or damaged.
The fusing unit can be removed and inspected(without removing any screws)(Left door)(lower handle).
If you see any damage you might have to replace the unit(or only the part if u r lucky).
