20 Most Recent Ricoh Aficio CL7300 DT2 Laser Printer Questions & Answers
you should go to interface setting and wath your ip . & after connect the lan cable install a tcp/ip device on you're pc and for ip write the ip youhave watched at interface setting .
Ricoh Aficio... | Answered on Sep 28, 2016
most likely bad black toner pump. you will need to call a tech is at least a two hour job and you have to take a lot of things out to replace it.
Ricoh Aficio... | Answered on Mar 05, 2015
opne then close paper trayy
Ricoh Aficio... | Answered on May 17, 2010
Look at the transfer unit. If the clear belt has alot of wear lines the belt needs to be replaced pn# B180 3780
The machine builds the alignment image on this belt and then reads it if the belt is cloudy it will fail.
Ricoh Aficio... | Answered on Mar 27, 2010
sc 541=Heating roller thermistor error (Fusing unit).
The thermistors could be dirty or damaged.
The fusing unit can be removed and inspected(without removing any screws)(Left door)(lower handle).
If you see any damage you might have to replace the unit(or only the part if u r lucky).
Ricoh Aficio... | Answered on Feb 11, 2010
This error is power related... their are two possibilities either... your fuser is blown or your machine needs a reset... here is a link to try the reset...
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
the reset should be all you need...
reset link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Ricoh Aficio... | Answered on Feb 08, 2010
If the media (glossy paper) is designed for an ink jet printer you should be fine.
Ink has to be able to be absorbed into the fibers of the page. If you are using paper for a laser color printer, that's your problem.
Don
Ricoh Aficio... | Answered on Jun 19, 2009
developer unit not set properly.
push the unit in tight
Ricoh Aficio... | Answered on May 06, 2009
I had the same problem, but solved it.
You have to connect your printer SP210 to your computer.
Search (in Windows) "Smart Organising Monitor Status"
Select Printer (new dialog box)
Click OK (see the error code SC545)
Click on User Tools
Printer Configuration
(Access Code is Admin074)
Find Fuser SC Reset under Maintanance
Click Ok
Close
Restart your printer
Your problem is solved now
OR
Without connecting your printer to Computer (you can do this):
Turn on the printer
Press C (Red colour centre) button once
Enter 107 (nothing will be shown)
Press the Green (Coping) button for 5 seconds
See the Display -->
Select Engine Maintenance
Select Ok
Select Fuse SC Reset (press down arrow - at down you will find it)
Execute (by Pressing the Down Arrow)
Done
Restart your printer.
Your problem should be solved....
Ricoh Aficio... | Answered on Aug 20, 2019
Check its connected to a network, the DHCP server is probably your router if you have a small or home network.
see
http://www.fixya.com/support/t25283562-solve_cannot_connect_dhcp_server_101#solution-section
Ricoh Aficio... | Answered on Jun 29, 2019
Probably, you will have to call your local Ricoh servicer for repair.
Ricoh Aficio... | Answered on Jun 27, 2019
SC 899 is a software error. For example printing from directly from a website. Various printing from websites makes 899 error. Just remove the print queue from the computer and that's it. Make sure you save the file first from the website before you print to avoid same problem.
Ricoh Aficio... | Answered on Jun 03, 2019
Ricoh Aficio CL7300 DT2 Laser Printer Logo
Popular Tags
17 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
printer not responding computer all
  • Office Equipment & Supplies
