I'm redoing the shelves in our parts room and I need to know what part goes together example if I want to keep all things that has to do with breaks together then I need to know all parts that go together when fixing breaks like bearings bolts etc
SOURCE: what type of steel break line is on a 1991 Chevy s10 blazer
It's probably 3/16" line with a normal flare. You can get a line from the auto parts store that has nuts and is flared already for a few bucks. You could remove one end of the line and see what kind of flare it has so you know which one to get.
The rubber "plugs "are the retaining pins,have to drive them out
with a punch and hammer. Also,have seen a lot if vehicles that
sit develop a restriction in the rubber hose that goes to the caliper,
The restriction is inside the hose so you can't see it. If this is the problem,after hitting the brakes ,open the bleeder on that wheel,
if fluid comes out under pressure and the wheel will turn after that,
it's the brake hose.
https://www.amayama.com/en/search/?q=2212027000
we mainly fix peterbilts, freightliners, Volvos so we mainly have parts for such
