Re: in Pennsylvania can a landlord lock out a roomer?
Need to look up the civil laws for landlord-- tenant in your local, county, and state laws each has laws and rules but in most states if a paying tenant no cant lock them out need to evict Overview of Landlord Tenant Laws in Pennsylvania Nolo com
if it is your antenna , call a local handy man operation for the job
if it belongs to the landlord it is his responsibility
if he refuses put in writing and then if he refuses again have the job done and send him the account
no, you certainly would not like to dance with that partner. Just go ahead and let your neighbors know you have to do some electrical repairs. A real safety concern, shut off what has to be shut off. Tell your landlord to go ...what is he? awful?
CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
Disconnect the heater return hose at the thermostat housing.
Disengage the ECT sensor and engine coolant temperature sender wiring connectors.
Disconnect the upper radiator hose from the thermostat housing connection.
Loosen the mounting bolts and remove the housing from the cylinder head.
Remove the thermostat and gasket from the housing.
Clean both thermostat gasket mating surfaces.
To install:
Position the thermostat gasket properly onto the housing. The gasket must be in place before the thermostat is installed.
Install the thermostat into the housing by first turning and then locking into the recess of the housing.
Position the thermostat and housing onto the mating surface of the cylinder head. Install and tighten the retaining bolts to 14-21 ft. lbs. (20-30 Nm).
Connect the upper radiator hose to the thermostat housing connection.
Connect the ECT sensor and engine coolant temperature sender wiring harnesses.
Connect the heater return hose to the thermostat housing.
Connect the negative battery cable.
Fill the radiator and operate the engine until it reaches operating temperature. Check the coolant level and adjust as necessary.
If you are talking about the headlight. The headlight assembly slides forward out the front of the car. The cheap plastic locks break easily. Practice on the passenger side, it is easier to see and touch. I have a 2003, hope it is the same.
Raise and support vehicle. Ensure that the transmission is in neutral.
Remove wheel and tire assembly.
Remove brake drum. Refer toBrakes, for proper procedure.
Clean all foreign material from housing cover area.
Loosen housing cover bolts. Drain lubricant from the housing and axle shaft tubes. Remove housing cover.
Rotate differential case so that pinion mate gear shaft lock screw is accessible. Remove lock screw and pinion mate gear shaft from differential case
Push axle shaft inward and remove axle shaft C - clip lock from the axle shaft
Remove axle shaft. Use care to prevent damage to axle shaft bearing and seal, which will remain in axle shaft tube.
Inspect axle shaft seal for leakage or damage.
Inspect roller bearing contact surface on axle shaft for signs of brinelling, galling and pitting. If any of these conditions exist, the axle shaft and/or bearing and seal must be replaced
CAUTIONWhendraining the coolant, keep in mind that cats and dogs are attracted byethylene glycol antifreeze, and are quite likely to drink any that isleft in an uncovered container or in puddles on the ground. This willprove fatal in sufficient quantity. Always drain the coolant into asealable container. Coolant should be reused unless it is contaminatedor several years old.
Some models require you to remove the air cleaner assembly from the throttle body.
Somemodels with cruise control have a vacuum modulator attached to thethermostat housing with a bracket. It your vehicle is equipped as such,remove the bracket from the housing.
On the 4-cylinder engines,unbolt the water outlet from the thermostat housing, remove the outletfrom the housing and lift the thermostat out of the housing. On allother models, unbolt the water outlet from the intake manifold, removethe outlet and lift the thermostat out of the manifold.
Fig. 1: Loosen the clamp securing the hose to the thermostat housingFig. 2: Remove the bolts securing the housing, then pull it awayFig. 3: Make a note as to which end of the thermostat fits in the housingTo install:
Clean both of the mating surfaces and run a 1/8 in. (3mm) bead of R.T.V. (Room Temperature Vulcanizing) sealer in the groove of the water outlet.
Fig. 4: Make sure both of the mating surfaces are free of any old gasket material
Installthe thermostat (spring towards engine) and bolt the water outlet intoplace while the R.T.V. sealer is still wet. Tighten the bolts 17-21 ft.lbs. (23-28 Nm) on all but the 2.2L engine. Other engines tighten to 89inch lbs. (10 Nm).
The remainder of the installation is thereverse of removal. Fill the cooling system, start the engine and topoff. Check for leaks after the car is started and correct as required.
