Brown stain in the water reservoir and carafe lid. How do I remove it?
Plastic can absorb Stains, so you will need to use some kind of bleaching poduct.
some products you can try individually:
Dilute with luke warm water , except for Rubbing Alcohol
Use some kind of tray which you don't mind if it gets bleach stains to protect your countertop. put the device on the tray.
If you can't soak an item, try disconnecting the device, then wrapping a lightly soaked hand towel or paper towel over the area that is discolored
Rinse with luke warm water, and make sure device has completely dried before reconnecting.
SOURCE: Cleaning my Faberware coffee maker
BRASSO, VINEGAR AND WATER OR C.L.R. ONE OF THIS MIGTH WORK
SOURCE: Water all over the place
the tube that attaches to the heating element is calcified inside. water cannot flow through it. i have the same problem and havetried vinegar solutions and even straightvinegar to loosen up the clog. no help so far. i am looking for a new heating element to fix it
SOURCE: Carafe lid
This puzzled us as well when we purchased ours. If you look at the top of the handle there are two little pieces that stick out on both sides. Lift these straight up and the lid will pop off.
Tina G
SOURCE: My thermal coffee carafe is
You can also use brewer's sanitizer. it is found at brewing stores but can be used for many things. Just make sure you dilute the stuff! It works on everything and is completely food grade safe. Sparkling new in just a few minutes!
