20 Most Recent
Cuisinart DGB-600BC 10-Cup Coffee Maker Questions & Answers
Replace the spring that holds the basket door closed
The spring can be replaced if you can get a new one - however it does take a lot of patience to get it aligned properly. I have purposely disassembled my 500 to clean out the tracks and basket latch and have successfully reassembled. In fact, right now I'm waiting for the coffee to finish to enjoy a fresh cup (although, all be told, at this point I'd rather go grab a beer! ;-) ) The trick with replacing the spring is that it has two different ends - one with a hook that is horizontal to the coil of the spring; the other hook perpendicular to the coil. The horizontal hook goes around the back peg of the latch lever, with this leg being against the bottom side of the lever. The other hook is used to maintain the tension and is placed against the side body of the sliding shelf. When placing the spring into place the angle of separation between the two legs is approximately 15 degrees - note: the legs do NOT overlap (ie, go past each other - they maintain their respective sides). The trick that I learned was to continue to apply downward force on the latch lever, thus forcing the retension peg to be as fully exposed as possible. This reduces the very frustrating occurrence of the spring slipping off the peg when you try to reinstall the cover. BTW, we've had this grinder/brewer for many years and thoroughly enjoy it - except for when the tracks gunk up & the basket spits out in the middle of brewing.....
10/9/2021 11:36:59 PM •
Cuisinart...
Answered
on Oct 09, 2021
DGB-600BC
I have had the Cuisinart DGB-600BC for a bit over a year. The coffee grinds, and then sometime during the brewing cycle, it will go, "beep beep, beep beep, beep beep..." on and on.
I think I have traced the problem to the latch on the top lid that you open to access the bean hopper. I believe the latch sticks and doesn't close the lid tightly enough. It will appear to be closed, but the latch isn't all the way in place.
So, there is a small screw on the inside of the latch in the lid. Carefully unscrew this, remove the screw, latch, and the small spring. Remember which way the latch faces.
With a warm damp paper towel, clean the latch and the slot in the lid that the latch goes into. Reassemble, and make sure the screw is not so tight that the latch doesn't move freely.
This should solve your problem.
12/28/2017 3:57:50 PM •
Cuisinart...
Answered
on Dec 28, 2017
Mr. Coffee Keiuger
Cuisinart offers a three-year warranty. For customer service call 800-726-0190 and they will walk you through the return process. There is a $10 fee for return shipping & handling. (Calif residents have other options, see your owners manual if you live in California).
4/23/2014 1:02:38 AM •
Cuisinart...
Answered
on Apr 23, 2014
