Working on embroidery and needle broke and messed up the design went to start the same design and saw the st/no counter way higher then the design called for. Is there a way to reset it back?
Reload the design you are trying to sew. Needle breaks can trigger circuit protection and affect the design being sewn from being saved in machine's memory properly..
Cheers,
Embroidery Services
San Diego, CA
Try turning the power switch on with the embroidery unit in place, insert the foot control. Then turn the power switch off, remove the foot pedal and turn the power on again. If that doesn't work, try inserting the foot pedal with the power switch in the off position, withdrawing it, then turning the power switch on.
Your motor was designed to shut itself down if it overheats or if stitching was interrupted. For instance, if your needle hit something solid and the needle bent or broke.
Generally, it will go on again in 10 minutes to 2 hours, depending on what the cause was. Occasionally, it can take longer. Using the foot pedal tends to reset the motor. I discovered this by accident one night, when I assumed that it was a Reset port and gently stuck the eraser end of a pencil in it until I felt resistance, then withdrew it. The machine had only shut down for about 3 minutes, but it turned right on again.
I used this machine in my middle school classroom. That message was in the first start up of the machine, I think it just resets the machine. The larger model also has a beginning reset button that just adjusts the arm of the machine. Is the machine working fine after the reset? Hopefully "sew"
If your embroidery is distorted be sure you are using the right stabilizer for the fabric you are doing the embroidery on and enough for the density of the design.
Be sure to install a brand new sharp needle before sewing. Check that the needle, thread, and fabric are compatible. An embroidery needle or top stitch needle may help.
When threading the top thread, ALWAYS RAISE the presser foot before threading to insure the thread seats in the tension disk.
truthfully I think their something wrong with the computer in the machine because the bobbin locked up. sometimes when a sewing machine jams it can make the machine jump time. but the needle moved positions, some part of the machine is changed during the jam up, even tho you reset it. embroidery machine are expensive, my suggestion is to have the machine checked
I have an Artisa 180. WHen the threads break I stop it and backup the stitches to where it broke. Read up on your machine and see if it can do this. Look for the icon on the embroidery machine that looks like an S with a tail! It allows you to move forward or backward in the design and find your place where the thread broke. It can salvage a design so you don't have to start over.
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
How long have you had your machine?
How long have you been doing machine embroidery?
Do you have a manual for your machine?
Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
Have you taken lessons for your machine or for embroidery?
When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
