20 Most Recent Elna 2007 Mechanical Sewing Machine Questions & Answers
ELNA CONTESSA 410
I have a Elna Contessa 710 Manual. If you think it will help I may be able to scan a copy and email it to your own email address. Plz supply email address if interested or still unable to thread machine.
10/11/2021 12:55:49 AM • Elna 2007... • Answered on Oct 11, 2021
2answers
My elna sewing machine bobbin
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
11/19/2019 9:01:11 AM • Elna 2007... • Answered on Nov 19, 2019
I used a single cam in my Elna Carina and I can't remove it. help!
ELNA Carina Instruction ManualPerhaps the spindle where the cam sets needs a drop of good quality sewing machine oil, like Tri-Flow Synthetic Lube. Be sure the stitch length & width are set to Zero. Elna Carina Electronic SU Duplex Review How to remove can from an elna Carina Its stuck and can remove it My...
12/20/2017 2:29:45 AM • Elna 2007... • Answered on Dec 20, 2017
Elna 700
If your machine did not come with a little screw driver, you will need to purchase a r flat tip screw driver. Usually, you can find small screw drivers in an eye glass kits too. Take your needle, your foot, bobbin, etc. all moving parts off and set aside. Then use your screw driver to remove the bottom plate. Sometimes it could be sitting right there you might can turn your machine upside down and you should here where it's at without having to disassemble the whole bobbing casing. I hope this was helpful.
12/11/2017 2:41:37 PM • Elna 2007... • Answered on Dec 11, 2017
2answers
Sewing Machine fault
Perhaps the manual would be helpful: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjv-KjEyNLXAhXDwFQKHZJtD4sQFggmMAA&url=https%3A%2F%2Ffiles.tv-sewingcenter.com%2F2015%2F04%2Felna-sew-fun-instruction-manual.pdf&usg=AOvVaw08q0vhbb6YSyyVVTwMCUKH ELNA Sew Fun Instruction Manual The feed dogs on your machine do not drop. Instead, the machine has a darning plate that covers the feed dogs (see the accessories listed in the manual). If the darning plate is installed properly, it should prevent the feed dogs from contacting the fabric. Make sure the stitch length dial is set @ 2 or higher. This will insure the fabric will move as the machine stitches. ..
11/22/2017 4:15:12 PM • Elna 2007... • Answered on Nov 22, 2017
2answers
My very old Elna Super foot pedal does not always
this sounds like the internal clutch drive is worn, it probably is not the foot pedal at all. It may be possible to repair it if you can track down an Elna serviceman. My Air Electronic SU got worn internally and my serviceman was able to repair it once for me.
9/6/2017 4:00:32 PM • Elna 2007... • Answered on Sep 06, 2017
3answers
Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
7/12/2017 9:32:58 AM • Elna 2007... • Answered on Jul 12, 2017
2answers
How do you thread the Elna Carina?
thought I had a manual with an image of this but can't find it.
But pretty simple.
tally_girl_31.jpg Place thread onto one of the spool pins at the back right, and pull thread across to the left and around the white blob on top of the machine head then back to the right to the little thread eyelet, down through this and down to the thread guide taking thread around it from the right and back up on the left side, back up and through the thread take up lever, then down again catching behidn the little thread guide, then to needle bar thread guide, then to needle eye.
ALWAYS HOLD THE two threads firmly behind the pressure foot when you start sewing - Really important.
Always wind and insert the bobbin with the holes on top, smooth side downwards. Place bobbin into bobbin holder and take thread take towards you and into the tension spring groove, pressing down on the thread with your finger until you hear it click into the tension spring. pull back the other way to check it is in there, if it comes out, do it again.
Bobbin will rotate anticlockwise when you pull the thread.
THen put needle plate cover down and draw bottom thread to the top using flywheel or the needle up/down button on these lovely machines.
Hope this helps, if not post again and I'll dig out images from my SU manual.
11/27/2016 3:46:32 AM • Elna 2007... • Answered on Nov 27, 2016
Elna sewing machine, the timing is out.
Hi, Purchased an elna contessa 130. could anyone advise threading procedures , as we do not have a manual with it.......problem with top tension.
Many thanks
Maureen
[email protected]
6/25/2016 12:46:31 AM • Elna 2007... • Answered on Jun 25, 2016
Threads jamming the bobbin case on elna sewing machine
Probably unevenly wound on the bobbin. Or tension needing adjusting, be careful to note where tension spring started before adjusting and do in very small increments. Perhaps the spring has some fluff stuck on it and thread cannot slide through easily. Take out bobbin and clean
11/2/2015 9:09:15 PM • Elna 2007... • Answered on Nov 02, 2015
How do I set timing on an Elna Carina 1980 model?
there is a service manual to download at this website http://www.arizonaexpressionz.com/elna_service/carina_500_service_manual.pdf
but it is written for a trained technician and may assume a certain level of expertise of the reader.
Hope this is of assistance to you.
If you are in the USA you could also contact White Sewing Center, www.whitesewingcenter.com - this gentleman actually trains how to repair sewing machines, and sells many Elna parts, machines and services them too.
10/27/2015 10:18:55 AM • Elna 2007... • Answered on Oct 27, 2015
Would a broken bulb stop an Lena machine from working?
Normally the light bulb function should not affect the machine's ability to operate, however, it could be if your machine is a computerized model. Try replacing the bulb and then test. ...
10/11/2015 4:07:08 PM • Elna 2007... • Answered on Oct 11, 2015
Feeder not moving
knotted up thread under the material indicates that the needle thread tension is incorrect ( needs tightening) once you have that correct the material, will feed normally use scrap when adjusting and the correct tension is when the top and bottom threads meet at the join ( middle -center )of the materials being sewn
9/8/2015 1:47:51 AM • Elna 2007... • Answered on Sep 08, 2015
2answers
The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
7/13/2015 1:58:48 AM • Elna 2007... • Answered on Jul 13, 2015
0answers
Contessa 320 sew
Be the first to answer 3/10/2015 1:01:26 AM • Elna 2007... • Posted on Mar 10, 2015Be the first to answer
Manuel elna su air electronic
I have a manual for the SU Air Electronic if you are still looking? you can email me on tallygirl98 at yahoo dot com and I'll send you a scan
2/1/2015 6:46:15 AM • Elna 2007... • Answered on Feb 01, 2015
Cant make the auto threader work on an elna 2007
Do you mean the auto needle threader?
Mine won't work on very small needle sizes so I resort to the old manual needle threader for these. Ditto for twin needles.
Otherwise its a case of pulling the auto threader down so the hook swings into the needle eye, then pulling the thread over the face of the needle and catching it into the hook, then release the threader so it pulls back through the needle eye, taking the thread with it.
The only other thing that springs to mind is "is the needle at the top position in its stich cycle so that the threader lines up with the needle eye?
hope these ideas help a little.
1/19/2015 2:28:39 AM • Elna 2007... • Answered on Jan 19, 2015
2answers
Elna 2002 -
The question was regarding the Elna 2002 not 2007 and it wasn't a problem. I just do not understand how the pattern selection works. Thank you.
1/3/2015 7:32:30 PM • Elna 2007... • Answered on Jan 03, 2015
Elna 2007 Mechanical Sewing Machine Logo
215 questions posted
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Elna Sewing Machines
Most Popular Question
manual elna lotus sp
  • Sewing Machines
