20 Most Recent Bernina Artista 180 Questions & Answers
Need owners manual
Hi there:About older manuals for Bernina Artista 170 or 180 available to download in PDF format...2_3_2012_2_28_29_pm.jpgImage link HERE.Try looking clicking in the previous links, we have in our database this Instructional Book; hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using FixYa, have a nice day.
11/30/2023 12:01:42 AM • Bernina Artista... • Answered on Nov 30, 2023
Need manual for bernina artista 180
You will have to order from a Bernina dealer.
11/30/2023 12:00:03 AM • Bernina Artista... • Answered on Nov 30, 2023
I AM LOOKING FOR A FREE BERNINA ARTISTA 180 MANUAL
here are 2 links for manuals, you can see if they are the right manual for the machine,, one is a free copy the other is nothttp://www.bernina.com/getdoc/d4dc2dee-97a4-4987-ac83-14a5e664b42d/Bernette_100_200_manualhttp://sewusa.com/Sewing_Machine_Manuals/Bernina_Manuals/180_Instruction_Manual.htm
11/29/2023 11:58:23 PM • Bernina Artista... • Answered on Nov 29, 2023
I need a user manual for bernina artista 180
Your manual is available here as a PDF for free http://www.bernina.com/en-CA/Support-9/Machines-2/BERNINA-artista-29 hope this helps
11/29/2023 11:55:23 PM • Bernina Artista... • Answered on Nov 29, 2023
My bernina artista180 won't power on
If your Bernina Artista 180 sewing machine won't power on, here are a few things you can try:
  1. Check the power supply: Make sure that your sewing machine is properly plugged into a working electrical outlet. Try plugging another device into the same outlet to ensure that it's working.
  2. Check the cord and connections: Check the power cord for any visible damage or wear, and make sure it's securely plugged into the sewing machine. If you see any damage or wear, you may need to replace the power cord.
  3. Check the fuse: There may be a fuse in the power cord or on the machine that has blown. Check the owner's manual for instructions on how to replace the fuse.
  4. Try a different outlet: If you're using a surge protector, try plugging the sewing machine directly into a wall outlet to rule out any issues with the surge protector.
  5. Consult a professional: If none of the above steps resolve the issue, there may be an internal problem with the machine that requires a professional technician to diagnose and fix.
If the issue persists, it may be best to contact Bernina customer support or take your sewing machine to a certified Bernina repair shop for further assistance.
2/28/2023 4:48:55 AM • Bernina Artista... • Answered on Feb 28, 2023
My Bernina Artista 200 freezes up after working
I hope you did not pay for it ! IAs a Techie, it is our responsibility to correctly diagnose. If he wasn't sure, it should have been sent to Bernina where it would be fixed!
10/7/2022 10:36:54 PM • Bernina Artista... • Answered on Oct 07, 2022
3answers
Bernina 440 stops stitching
see your local dealer and tell them you have a bad power board. or l-print. this is a known issue and bernina is covering it under there 5 year warranty. the 5 volt output is faulty on some some models
7/8/2022 1:05:29 AM • Bernina Artista... • Answered on Jul 08, 2022
Why doesn't it recognize that an embroidery hoop is attached?
Perhaps this will help: My Embroidery Haven View topic Bernina 180 Bernina artista hoop not recognized You can also try contacting the Support group at Bernina.com or your local Bernina dealer ...
12/1/2021 11:31:52 AM • Bernina Artista... • Answered on Dec 01, 2021
How to change hoop size in my Bernina Artista 180
I don't have a bernina.. but on my Janome... I have to "tell" it what size I'm using by selecting it from the menu.
11/29/2021 10:50:47 AM • Bernina Artista... • Answered on Nov 29, 2021
Bernina 180 Artista sewing machine
you may have to replace the upper thread sensor
10/30/2021 12:45:35 PM • Bernina Artista... • Answered on Oct 30, 2021
The touch screen of my Bernina 580 stopped working today and it was perfectly OK yesterday. Is there a way to fix it on my own or should I look for help?
Calibrate the diplay The Display calibration can be opened as follows: - turn off the sewing-/embroidery computer - touch the two needle positioning buttons on the front panel and keep them pressed - turn on the sewing-/embroidery computer and release the buttons as soon as the Display appears - touch the calibration icon - touch the center of the cross using the touch pen -- the cross moves to the next position - repeat this until all three positions shown are calibrated -- the Display is closed -- the adjustment is saved
10/26/2021 12:06:24 PM • Bernina Artista... • Answered on Oct 26, 2021
3answers
Bernina 830 won't zig zag, won't buttonhole, no decorative stitch
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps, I know it will.
10/10/2021 11:19:25 PM • Bernina Artista... • Answered on Oct 10, 2021
Why won't Bernina Artista 630 turn on?
If the machine won't power up its most likely a problem with the power board inside of the machine. I have replaced a bunch of bad power boards on the 600 and 400 series Berninas over the years. The 600 and 400 series machines use the same board. I service and sell lightly used Berninas on eBay under the user name bushvideo.
8/23/2021 11:19:07 PM • Bernina Artista... • Answered on Aug 23, 2021
How do you adjust the tension on a Bernina 180
There are two tension adjustments, which should be done with a proper set of weight gauges - top and bottom thread tension should be carefully balanced to get the best stitch formation. It is best that you assume the top tension is correct and adjust the bobbin tension to match. Load the bobbin with thread of one colour and put a spool of the same thread but a different colour on the top. Thread-up the machine, load the bobbin and sew-off a satin-stitch on max width zig-zag. In this configuration, there should be a very small 'bead' of the top thread showing along each side of the satin-stitch on the underside of the material. If there's excessive top showing, the bobbin tension is too high and if none, the bobbin tension is too low. To adjust the tension, remove the bobbin case and you will see a spring around the edge with two screws through it. One of the screws holds the spring in place and the other adjusts the tension - this is furthest from the edge of the spring and is in a small 'cup' in the spring itself. To reduce tension, turn the screw VERY SLIGHTLY anticlockwise and to increase it turn it clockwise. Make very slight adjustments and re-check sewing-off the satin-stitch every time until you get the required thin line of top showing down each side of the stitch on the underside. Ideally this should be done with Mettler Metrosene thread, but as we're just balancing against the top tension, it shouldn't matter too much provided you use a good thread top and bottom.
6/2/2020 4:50:14 AM • Bernina Artista... • Answered on Jun 02, 2020
I have a bernina artista 180 and have just bought the embroidery module. When I connect the embroidery module the machine seems to think I have the free arm adaptor attached & not the full module.
I'm not real familiar with this issue but my first thought is the format of the program is wrong. You have to have the right format or the program is similar to you reading Chinese.
2/2/2019 7:36:18 PM • Bernina Artista... • Answered on Feb 02, 2019
Bernina 180 Embroidery Freezes up during stitch out says it is busy. Shows the hour glass for re calculating.
Often it has to do with overload and or the side port has a faulty soldering joint. Either replace at cost of $120 including labour or remove port and solder loose joint
1/27/2019 8:30:07 PM • Bernina Artista... • Answered on Jan 27, 2019
3answers
I need a Bernina 830 condenser
Do you mean the multi-part condenser that's used across the motor windings, or the one in the foot controller ?
1/20/2018 8:43:51 AM • Bernina Artista... • Answered on Jan 20, 2018
Needle positionioning? Bernina Artista 200
Suggest taking it for service. This appears to be a machine malfunction that probably calls for a professional to resolve.
1/19/2018 2:30:37 AM • Bernina Artista... • Answered on Jan 19, 2018
My light keeps going out. If I push the power
working with Electrical parts "wires" is not something i would recommend unless you are an electrician but how ever i would try a new bulb first if that doesn't cure it i would take it back to your repair man who repaired it before
12/27/2017 12:43:09 PM • Bernina Artista... • Answered on Dec 27, 2017
How do I reinstall the spring loaded feed dog system.
Oh, you may need to have a technician do that. The feed dogs need to be installed to certain specifications that are difficult to do without the proper tools and knowledge.
11/16/2017 12:25:44 AM • Bernina Artista... • Answered on Nov 16, 2017
Sewing Machines Logo
600 questions posted
Top Bernina Sewing Machines Experts
ZJ Limited
ZJ Limited
Jesse Walters
Jesse Walters
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bernina Sewing Machines
Most Popular Question
bernina 440 stops stitching
  • Sewing Machines
