GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator Logo
B
Barbara Elkin Posted on Mar 18, 2016
The machine stops with S9 flashing - GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
Trouble with getting a Janome S9 to update. Using a usb version 3 flash drive. Will not recognize data on flash drive.
What is the capacity of the drive? You are probably using too large of a USB flash drive or it is formatted with the wrong file system. Most USB 3.0 drives will be formatted to NTFS. The drive needs to be formatted as a FAT or FAT32 drive with a 32 kilobyte sector size. Janome claims that the largest format USB drive that is compatible with the Skyline S9 is 16GB. Not all USB drives of this capacity or smaller are tested and proven to work with this sewing machine. See https://www.janome.com/siteassets/support/technical-support/skyline-s9/formatting-your-usb-stick-for-first-time-use-skys9...pdf for formatting a drive from the sewing machine. To format the drive first at the computer, https://www.janome.co.jp/e/e_downloads/soft/update/skylines9_atelier9/how_to_format_the_USB_flash_drive.pdf . Sometimes you can also get a driver issue. There are some USB drives that require a driver to be installed to be able to read the drive.
I hope this help.
Not able to get emails incoming to my Samsung galaxy tab 2 ?
Troubleshoot issues related to email on your Samsung ...
support.sprint.com/...email...Samsung-Galaxy-Tab.../...
Sprint CorporationYou may have email issues if you're unable to: Send emails; Receive emails ... Scroll to and tap My Device. ... If your Samsung Galaxy Tab 3 7.0 is still unable to connect to data, ... My rating. 1 2 3 4 5. Give us your comments. Send Cancel ...
Samsung Galaxy Tab 10.1 - Email stops syncing - Android Forum ...
https://www.androidpit.com/.../samsung-galaxy-tab-10-1-email-stops-syn...
Just bought Samsung Galaxy Tab 4 and set up my email to receive from my emailserver. ... Aug 8, 2014 2:14:33 PM via Website. Aug 8, 2014 2:14:33 PM via ...
How to change the email settings on my Samsung Galaxy Tab
support.bell.ca/.../Samsung_Galaxy_Tab.how_to_change_th...
Bell CanadaNote: Entering the wrong mail server settings can stop your Samsung Galaxy Tabfrom sending and/or receiving email. If you can't get the mail server to connect, ...
How to Receive E-mail on the Samsung Galaxy Tab - For ...
1helpful
2answers
What does 2 flashing blue light mean on the S9.
Blue (three flashes) powering on/enabling indicator light
Blue (steady) pairing mode
Blue with 10 quick purple flashes
pairing successful
Blue (long flash)
standby (connected but not
on a call or streaming music)
Blue (quick flash)
incoming call
Blue (long pulse)
on a call
these are all the normal blue flashes that the s9 makes
1helpful
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
22helpful
S9 nvr goes into paring mode
Hello,..... when pair the S9 you must press and hold down the power on button till the led flashes blue and red...at this point it will be in pairing mode....
2answers
Top Refrigerators Experts
vince
Johnny 1000
