SOURCE: my machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
SOURCE: Have Viking Husqvarna #1+ sewing machine that when
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
SOURCE: Singer 2259 - The machine has stopped moving, the
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
SOURCE: Problem with a husky lock 340 serger. Wheel on
My Bernette did exactly the same thing as you describe and when I took it to the mechanic there was a gear right inside that had split on the main drive path. It was a nylon gear and it had cracked right through the middle - my machine was about 12 years old at the time.
After one store advised I junk the machine, I then priced the part from Bernina head office, spoke to another mechanic and he was able to send my machine to another mechanic he knew who could pull the thing apart quicker because he'd done the repair before. I was warned it would cost $270-350 but I love the machine so said go ahead.
I'd suggest you take your husky to a local husky dealer for a quote on this, it does sound similar.
SOURCE: The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
