20 Most Recent
Brother Limited Edition LS2250PRW Project Runway Sewing Machine Refurbished LS2250PRW Questions & Answers
Turning wheel disconnected from motor?
I would try replacing the needle, as it may have got bent. I have had this happen and I was sure needle wasnt effected. when I changed needle it was fixed. The very tip of my old needle had a slight curve and wasnt connecting to correct spot on throat plate. make sure you have needle in highest position and that stitch selection in turned back to straight stitch.
My brother exedra e-40 #db2-b737-413
- In the event that changing the needle didn't determine the issue, have a go at rethreading the machine, guaranteeing legitimate pressure, and cleaning the bobbin region for any build up or garbage. On the off chance that the issue continues to happen, consider counseling the machine manual or looking for proficient help.
Brother XL5600 is not stitching properly and dropping stitches?
need to check the hook timing.
put it in zig zag, no fabric, turn the hand wheel to you slowly.
check the needle when it is coming back up, is the hook picking up the thread? if yes continue to check the next side, so if you check the left side then check the right. if any side its not picking up the thread then the timing is off and need to be retimed
