Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
You can only print on envelopes with the computer.
Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive
Prepare envelopes.
Press down on all four corners and edges of the envelopes to flatten them.
If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
If the corner of the envelope flap is folded, flatten it.
Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm).
Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide
(A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide
(A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides.
(5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
Be sure to open the paper output tray when printing. If not open, the machine cannot start printing.
After loading envelopes
Select the size and type of the loaded envelopes on the print settings screen of the printer driver.
You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
I fixed it. I disassembled the tray to see how it works. Once opened I tried bending the plate while trying to collapse. Then I applied a little bit of silicon grease and now collapses smoothly. Very poor design indeed.
