Vizio VO47L 47 in. LCD TV Logo
A
Arlis Whittington Posted on Jan 19, 2016
How do I adjust the picture to fit the screen? There is a 2 inch band on all 4 sides
1 Related Answer
dave1645
Dave Naylor
  • 834 Answers
  • Posted on Nov 18, 2009
SOURCE: Orange 2 inch line appeared on left side of screen ,then no pictu
it could be jusr a bad connection on th LVDS cable or your panel has died
have a tech check it out or send it to Tops Electronics in Haverhill ma
Picture doesn't fit screen. A 1-1/2 inch wide band on top and bottom of screen. Have tried the picture button on remote but it only gives me options ie: Panoramic, standard, wide etc. Nothing seems to
Many units will self adjust the image size, but the size of the image you will see depends on what size it was originally recorded in. You can change it in the settings of the TV but most likely it will not go bigger if it was shot smaller.
I lost my remote, and the picture is smaller than the actual screen by about 2-3- inches on all sides. how do i enlarge the picture to fit the screen?
This function u can't do it without the tv original remote.Try website like Remotes.com to buy the tv original remote.Than used one of those buttons on the tv remote like View Modes,Picture Sizes,Aspect Ratio,Zooming to do the adjustment for tv screen pictures sizes.
Hi, I was recently given a Samsung Syncmasster 2333sw flat screen monitor that I hooked up to my old Dell Dimension 8200 desktop.The monitor says the optimum resolution is 1920x1080 pixels. The maximum the...
hi bob you should be able to adjust the screen size via the menu on the monitor itself, (Available in Analog mode only) Note When TV signal is input in AV mode ,select “Screen Fit “to adjust vertical position in 0-6 levels. Image Size Note Supplied for the wide models only such as 16:9 or 16:10. You can change the size of the screen displayed on your monitor. PC signals • Auto - The screen is displayed in accordance with the screen aspect ratio of the input signals.• Wide - A full screen is displayed regardless of the screen aspect ratio of the input signals. Note • Signals not available in the standard mode table are not supported.• If the wide screen which is the optimal resolution for the monitor is set on your PC, this function is not performed. AV signals • 4 : 3 - Sets the picture to 4:3 normal mode. • 16 : 9- Sets the picture to 16:9 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • 4 : 3 - Sets the picture to 4:3 normal mode. • Wide-Sets the picture to 16:10 wide mode. • Screen Fit- Use the function to see the full image without any cutoff when DVI (480p/576p/720p/1080i/1080p) signals are input. Note • It can only be selected if an external input is connected to the DVI terminal and the 'PC/AV Mode' is set to 'AV'. • When the panel is of 16:10,the screen size options include “4:3”,”wide “,”Screen fit“.hope this helps
2answers
Band adjustments for a 5r55e
You'll never be able to get your hand in between the floor pan and trans,so forget it.
You bring the band down tight and the back off 1 1/2 turns,only when rebuilding or reassembling it. If the band wears to the point you need adjustment,your in big trouble. Also,if you go the wrong way with the screw and the band falls off,your really in a serious crisis and may have to pull trans.
1helpful
3 problems 1. TV shuts off and on automatically. 2. 2 inch band on left side of screen 3. No picture at all
The band or shadow on the left side of the screen definitely sounds like a defective light tunnel.As for the intermittent pix and shut down this could be the lamp if you have not already changed it.
1helpful
Tv out of alignment
the picture shifted 2 inches to the right
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
1helpful
Jeep grand cherokee revs for to high before changing gear
Message:
My 2002 Dakota has been somewhat confused about shifting as well. It showed a code P1762. I dropped the pan to install a new fluid filter and fluid-(use only ATF+3 or ATF+4). Since the pan was off I decided to adjust the bands. The front band controls the 2nd gear cluster. The rear band controls the 3rd gear cluster and reverse. For a 2-3 shift, the transmission shifts back to 1st gear with the front band while the rear band engages 3rd gear. If the front band does not release the 2nd gear clutches before the third gear clutches engage, the transmission binds, which shortens the life of the transmission clutches. If the front band releases too early in the shift, the engine will overspeed (sounds and feels like a slip) during the 2-3 shift.
The front band adjusting screw is on the driver's side above the shift linkage. The rear band is inside the fluid pan near the filter.
1. Loosen band adjusting screw locknut. Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw
threads if necessary. The front band adjuster is on the outside of the transmission and the locknut requires a 3/4" wrench.
2. Using Inch Pound Torque Wrench C-3380-A, a 3-in. extension and appropriate Torx� socket (T-40), tighten adjusting screw to 72 in-lb. CAUTION: If Adapter C-3705 (from SPX Miller) is needed to reach the adjusting screw, tighten the screw to only 47-50 in. lbs. torque.
3. Back off adjusting screw the number of turns listed below for your transmission.
4. Hold adjusting screw in place and tighten lock-nut to:
41 N�m (30 ft. lbs.) for the front band
34 N�m (25 ft. lbs.) for the rear band
The adjustment screw inside the case is a square head bolt. You will need a 1/4 square head socket to fit your torque wrench.
Band adjustments for each model year:
1994
* Front Band - tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
o 32/42RH - Tighten to 72 in-LB, back off 4 turns
o 36/37/46/47RH - Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
o 42RH - tighten to 72 in-lb, back off 2-1/4 turns
o 46RH - tighten to 72 in-lb, back off 2-7/8 turns
o 47RH - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE/RH - tighten to 72 in-lb, back off 4 turns
o 46RE/RH - tighten to 72 in-lb, back off 2 turns
o 47RE/RH - tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
o 42RE - tighten to 72 in-lb, back off 3-5/8 turns
o 46RE - tighten to 72 in-lb, back off 2-7/8 turns
o 47RE - tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
o 42RE - tighten to 72 in-lb, back off 4 turns
o 46RE - tighten to 72 in-lb, back off 2 turns
o 47RE - tighten to 72 in-lb, back off 3 turns
1999
* Front Band
o 42RE - tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
o 47RE - tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
o 47RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
+ The 47RH rear band requires a 1/4" hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
o 42RE - Tighten band adj. screw to 72 in-lb, back off 3 turns
o 44RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
o 46RE - Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
o 47RE - Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
From Bill Konolday's 47RE notes: I usually go a little looser than factory
specs on this front band - backing off the adjustment screw 2 or 2 1/4 turns.
Depending on the circumstances I have backed off the band up to 2 1/2 turns.
* Rear Band
o 42RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 44RE - tighten band adj. screw to 72 inch pounds, back off 4 turns
o 46RE - tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
o 48RE - tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut - 30 ft-lb
* Rear band adjustment locknut - 25 ft-lb
* Transmission pan bolts - 13 ft-lb
I just replaced the solenoid with the recommended transducer and all is fine now. The transducer cost me about $50 at a nearby dealership.
Hope this helps. -zman. [email protected]
Phillips Plasma Picture Way Off Center & A Static Line Appears
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
