20 Most Recent
Philips 32PFL5403D/27 32 in. LCD TV Questions & Answers
Hard reset philips tv
A hard reset (reboot) is achieved when the television is unplugged while on. The unit should remained unplugged for at least 60 seconds.
3/26/2019 10:44:49 AM •
Philips...
Answered
on Mar 26, 2019
HI
FEW DAYS AGO I GOT
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ..
7/25/2017 12:58:51 PM •
Philips...
Answered
on Jul 25, 2017
Sound is clicking
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box.
7/26/2014 11:09:54 AM •
Philips...
Answered
on Jul 26, 2014
Video component
If you check in your owners manual, it will tell you that movie formats are not supported. See quote from your owners manual below (so basicly only picture and music formats are supported on your USB input). "Only FAT (DOS) formatted (initialized) portable memory issupported. Errors in this formatting can result in unreadablecontent. If such problems appear try to re-format the card. Beaware that formatting the card will also delete all the content on it (pictures, music, ...). The following file types are supported: .jpg, .jpeg, .mp3, .alb, .m3u and .pls."
11/8/2013 6:00:07 PM •
Philips...
Answered
on Nov 08, 2013
My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
6/10/2013 7:25:52 AM •
Philips...
Answered
on Jun 10, 2013
