LG LFX25960ST Stainless Steel French Door Refrigerator Logo
A
Anonymous Posted on Jan 04, 2016
Leaking and ice maker is not working
My refrigitor is leaking and ice maker is not working
Jerry Beacom
Level 1:
New Friend:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Apr 18, 2017
Jerry Beacom
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
18
Questions
0
Helped
7739
Points
20
Your ice maker freezer fan may be iced up. Take the freezer bin out and look at the back of the freezer. If there is ice built up, you have to defrost it.
5 Related Answers
Anonymous
  • 3773 Answers
  • Posted on Aug 14, 2011
SOURCE: The ice maker appears to be working fine. However,
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Anonymous
  • 112 Answers
  • Posted on Jul 20, 2010
SOURCE: Water is leaking down the inside of the freezer
you have a plumbing problem...the connections have come lose or the seals are perished.
Avi
  • 66 Answers
  • Posted on Jan 29, 2011
SOURCE: Ice build up on floor of freezer drawer starting under ice maker
since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Sep 10, 2011
SOURCE: LSC27926ST REFRIG/freezer. Ice maker
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
vinceisaac
francoise cleofas
  • 2432 Answers
  • Posted on Aug 11, 2012
SOURCE: my ice maker on my lg refrigerator is leaking, what do i do
tried to drain and clean first to see where the leak came from.
1helpful
Water leaking and no water to ice maker?
pull fridge out
unplug
turn off supply faucet to ice maker
check line and fridge connection for the leak usually at the frige.
repair as necessary
turn on water
check for leaks
Mike
3answers
Blue liquid leaking from ice cream attachment
I have been debating as to whether to buy one of these ice cream units but it appears it would be a big waste of money. I wonder how to track if Kitchenaid has made improvements to fix the flaw in the unit.
1helpful
Ice maker is leaking
The ice maker fill valve is faulty.This valve located at the back of ice maker is not functioning properly,so water is leaking. Change the Water enter dump valve for the ice maker. It is leaking. It will not shut off & will cause this problem. It`s infrequently located in the rear of refigerator usely where water line enters the electrically back of refrigerator. In essence the valve and electric head can be bought at any Appliance Parts store. --------------------------- thank you.
I have water leaking from the lower left rear side of my Kenmore Elite side-by-side with the ice maker ON.The leaking stops by turning the ice maker off-the water dispenser works fine with the ice maker on...
there are 2 pipes going from the pump at the bottom of your unit ... 1 to the ice maker and the other to the filter for water.
make sure the pip for the ice make is tight in the connector of the valve ... let me know...
Water from ice tray is leaking onto ice and making ice cubes become melted together.
Most of the times the solenoid is leaking (electric valve that lets water to the ice maker when it calls for it) and when the ice maker calls for water it' ll overflood.To make sure this is the problem , shut of the ice maker and next day look inside of it , if is water , the solenoid is leaking and has to be replaced , if not the problem is with the ice maker and has to be repair or replaced.
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Ice maker is leaking water. Never has worked well takes for ever to spit out ice. Now ice is all over everything in freezer since leaking but will still make some ice. I have had for 2 years/.
Do you have a water softener? This puppy won't work right if you do. ice maker leaking water? Ok lets do the scenario. This fancy ice maker will fill the ice mold in stages according to resistance levels measured by the control inside the IM. I initially will judge resistance in the ice mold and then will call for water. It will again judge for full ice mold by checking resistance. The 3rd attempt will supposedly satisfy the requirements of the ice mold. If the water softener goes into reverse osmosis(that time or the month for water sofeners). Then electrolysis will occur in the ice maker and some different resistance readings from what is built in is read. Oops! overflow of ice maker and weird ice production. Solution. Remove ice maker from the loop. Water softening is good for the clothes but hell on the ice production.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Ice maker leaking
yes go to sears parts center and buy the ice maker part # 4317943 thats if the ice maker is in line is leaking because the mold inside is peeling off due to the wtr being to hard repl ice maker is realy easy loosen screws remove harness and repl new one that is all you might not need all parts in box
1helpful
Amana side by side ice dispenser leaking water
Take the ice maker out and look at the mold. If the coating is flaking off then that is where it is leaking. Will need to replace the ice maker.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
