Insignia Solutions Original INSIGNIA TV remote control for NS-39D310NA15 NS-48D510NA15 NS-19E310NA15 NS-24D510NA15 NS-28D310NA15 NS-32D310NA15 NS-32D510NA15 NS-50D550NA15 NS-42D510NA15 NS-40D510NA15 NS-32D311NA15 NS-55D550NA15 NS-29D310NA15 NS-32D512NA15 NS-32D312NA15  Logo
P
Pam Beckert Posted on Nov 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
I pushed something on the TV remote and lost all channels. A scan for channels did nothing.
Level 3:
Top Expert:
  • Insignia Sol... Master 76,851 Answers
  • Posted on Nov 29, 2015
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008274
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
I lost my remote to my Insignia TV, how do I set my Radio Shack remote Cat. No. 15-302 to set my Insignia TV?
MOST REMOTE CONTROLS ON THE MARKET WORK MANY TV SETS. MOST TV HAS A CHANNEL FOR TROUBLE SHOOTING AND SETTINGS.
8helpful
2answers
Can i change the input settings without the remote
pls check from channel one to zero you can see AV input.
Remote to Insignia Digital converter box will not do anything but turn unit on/off, although the light does flash when buttons are push - nothing happens.
Well, try it two different ways, as follows: But be sure that the tv-channel that's selected for tuning will be identical to the "output-channel" which you'll then select for the Insignia converter-box. So, if you first select Channel 3 for tuning the tv set, then you must later select Channel 3 on the "Output Channel" choice for the Insignia "set-up" menu. Similarly, if you first select Channel 4 for tuning the tv set, then you must later select Channel 4 on the "Output Channel" choice for the Insignia "set-up" menu. Be consistent! If you find that the Insignia menu-screen does not subsequently appear after tuning the tv to Channel 3, then start-over with Channel 4 as your proper tv-tuned station to initiate the pop-up screen for the Insignia menu.
Now, here's an example that assumes Channel 3 is the proper tuning-station for your tv-set within your particular region: You will first tune your tv-set itself (by means of its handheld tv-remote) to Channel 3. Be sure, however that your Insignia converter-box is turned-on and properly connected to your tv-set and antenna.
On your tv's hand-held remote-controller, you should find a button that serves as its "input selector" -- with a typical descriptor such as "Input" or "Line" or "Video/Antenna." Press that button, and enter successive channel numbers until you get to Channel 3. You may need to press the digits 03 to signify Channel 3. The tv-screen may be colored bright blue at that point.
Then, as you switch to holding your Insignia remote-controller, press the "Menu" button. (Please note that you will need to press hard and firm upon the buttons of the Insignia hand-held in order to get proper responsiveness; a quick touch of the button will not be effective.) After pressing the "Menu" button, the Insignia menu should now appear on the tv-screen. Now, you need to use your Insignia hand-held remote-controller (not the tv hand-held remote-controller again) to travel through the menu-screen to the "Setup" feature. Then, select "Output Channel." Proceed to select Channel 3 -- which will then be printed for you next to the Output Channel feature. Finally, under the same Setup menu, go to "Auto Tuning" -- which will commence a complete scan of all available channels.
Remember, if tuning by Channel 3 is inappropriate for tv-tuning within your particular geographic region, then repeat the above process by substituting Channel 4.
When you are done, you will rely almost exclusively upon the Insignia hand-held remote controller. You do not especially need to use your tv hand-held remote-controller again.
However, be sure to avoid standing in front of your tv-set to change channels by buttons or knobs upon the tv-set itself. Tuning again upon the tv-set itself will negate your prior tv-setting for either Channel 3 or Channel 4 -- and thereby sabotage your working set-up!
I myself incurred chronic anxiety yesterday (June 13), as I was stunned that the Insignia menu-screen did not appear immediately when I pushed "menu" on the Insignia hand-held.
The only buttons that worked on the Insignia handheld remote-controller were the Power-on for the converter-box and the Power-on for the tv-set.
(continued next page)
Because my expectation had been this process would take just a few minutes, I was deeply frustrated and impatient. However, I recognized that my apprehension of impending loss was absolutely appropriate as emotional "signal-processing" for me personally -- in contrast to my formerly high expectation of immediate fulfillment, completion, and gratification. Instead of my intention for quick success, I faced the stunning dread that the Insignia box had become defective or that I'd fail to ever figure-out the problem. I would not have been so impatient if I hadn't expected immediate success for the set-up.
I rejected the slogan that "I just want to get this over with!" I rejected the option of stomping upon the Insignia box! Amidst my hour-long anxiety, I summoned "Courage" -- a mode of patience to accompany my internal "quivering." I did a Google search.
From this Fix-Ya web-site and other troubleshooting sites, I had strong clues that improperly setting Channel 3 or Channel 4 was a primary culprit for the failure of the Insignia's menu-screen to appear. When I finally succeeded, my anxiety dissipated quickly with a temporary relief. But then came the anger that the Insignia "User Guide" had not been clear to explain the process. From that aftermath of outrage, I decided to promptly compose this protocol to assist others who have been similarly tormented -- perhaps to the extent of incorrectly believing that the Insignia converter-box was a defective product requiring prompt replacement.
Lost remote want to get to input channels using side buttons on TV
Try using the manual buttons and keep pressing channel down until you see the lowest station you receive, then go slowly.
Maybe Insignia put the inputs into the channel search automatically.
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
4helpful
Insignia remote will not turn on or off the TV
Setting the Remote to control power on your TV is really easy. You just hold down the TV power button and you start pushing UP on the channel button.
Lost Remote
First you want to go press the menu button on the front of the tv. Second, choose channel set. Third, choose add/delete and manually preset each channel. You can try just adding channel 3 if you have cable. This will turn the tv back on and out of game mode...
3answers
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Top Insignia Solutions Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Insignia Solutions Televison and Video Expert? Answer questions, earn points and help others
