20 Most Recent Insignia Digital-to-Analog Converter for Analog TVs Questions & Answers
5answers
Looking for code to run Insignia digital converter box
If you have a GE universal remote try code 0656
2/1/2019 3:32:01 AM • Insignia... • Answered on Feb 01, 2019
Insignia ns-dxa1-apt remote control does not tv power button does not work
Try changing the batteries in the remote.
1/17/2018 3:33:54 PM • Insignia... • Answered on Jan 17, 2018
3answers
Don't get ABC or NBC local channels anymore
ATSC tuners ("D/A converters") pick up signals off the air just like old school television. It sounds like you are just not getting a signal of sufficient strength. A weak analog signal looks like a "snowy" picture, which most of us are used to. But, the new digital channels quickly go from a perfect picture to none at all. It's basically all-or-nothing.
Try attaching an antenna to your converter. I know you can buy a new antenna from your local big box electronics store which is labeled "Terrestrial HDTV" or something, but that really doesn't mean anything. You can use any old TV antenna. Even a quality FM antenna (with an F-Pin coax connection) may work just fine.
When setting up the antenna, keep in mind that different channels are transmitted from different towers, in different locations with different strengths. Move the antenna placement and position around (just like grandpa had to do). You may have to make a compromise to get the best signal for your favorite channels.
1/17/2018 1:33:59 AM • Insignia... • Answered on Jan 17, 2018
Programming Insignia Digital Box to Phillips Universal Remote
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
10/30/2017 6:31:42 PM • Insignia... • Answered on Oct 30, 2017
Sound problems with recording to vcr using converter box
If your TV has no scart connection, no HDMI connection, then to be honest I would get a new set. There are plenty of good second hand models around, which will be better than your old set and come with a digital tuner built in. As for the VCR, that should have a scart socket and so should the converter box. Once connected via the scart socket you should be be able to record the shows easily. If the converter box comes with a volume control, you might need to set that up to get it right. If the VCR has two scart sockets use the second one to connect the box. Use the first to connect to the TV for viewing your recordings only. If it has only one scart, then look around on Amazon for one of these scart switching boxers. scart box-2ezdezzc42qgaoqqik1m5pt1-2-0.jpg
3/20/2017 1:23:07 AM • Insignia... • Answered on Mar 20, 2017
Sound quality and Freeze up issues with Insignia Converter Box
Tiling is caused by a weak signal, it is the only reason
3/15/2017 12:43:33 AM • Insignia... • Answered on Mar 15, 2017
3answers
Connect tv vcr and dvd player to digital converter box
Yes you can first connect the converter box to the antenna first. Next hook the tv out on converter box to vcr in on vcr. Next hook the vcr out to the tv in and watch vcr and converter box on channel 3 sometimes channel 4.on the actual tv and of course change channels with converter box remote. For dvd player hook it straight to tv with red,white,and yellow cables that come with your dvd player. Then to watch dvd player if it's hooked up that way you have to put your tv on a input like video 1 or input 1. This can be done by using the tv remote and looking for a button that says tv/video or input or source button. This is some common names for that button on tv remotes. I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
12/3/2016 3:16:39 AM • Insignia... • Answered on Dec 03, 2016
My tv won't take commands from my remote, it will shut down, but not restart
If you are using a none original remote then not all remote codes will work all the functions. Some codes are designed for different models. So you might have to try several codes before all functions will work. Even then some might still be missing. If you are using a new genuine remote and it's still playing up. Then either two possibilities can occur. The set has been switched to work a different remote. Or there's a fault in the set that has either effected the remote functions or has caused the functions to cease to operate, even though the remote is sending out the correct signal and the set has received it.
9/26/2016 5:43:25 PM • Insignia... • Answered on Sep 26, 2016
How do I make the picture on tv screen?
on the tv screen select the correct input source when the set top box is switched on--av1 or 2 or 3 etc
4/22/2016 10:14:55 PM • Insignia... • Answered on Apr 22, 2016
0answers
Why won't it scan?
Be the first to answer 12/26/2015 2:10:54 AM • Insignia... • Posted on Dec 26, 2015Be the first to answer
2answers
Hearing my television through my home theater system
Without knowing anything about your TV receiver all I can assume is that the TV has a least an RCA analog audio OUT. Run that to any available analog input on the HTS. make sure the TV's audio controls (hidden in a menu somewhere) is set to Fixed so the TV volume won't affect the HTS volume. Then you can turn the TV speakers off and still listen through the HTS.
You'll only get stereo this way. Ideally, you would have a digital audio source for the TV audio signal.
10/2/2015 3:43:56 AM • Insignia... • Answered on Oct 02, 2015
How do I get this thing to work?
to tv to antenna If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
9/24/2015 10:43:31 AM • Insignia... • Answered on Sep 24, 2015
How to hook up vcr to tv
you can use rca jacks red white yellow or coax cable out to tv in to vcr If you need further help, I’m available over the phone at https://www.6ya.com/expert/richard_b59056c0c62ecb00
9/24/2015 10:35:18 AM • Insignia... • Answered on Sep 24, 2015
Insignia Digital-to-Analog Converter for Analog TVs Logo
364 questions posted
Top Insignia Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Audio Players & Recorders
Most Popular Question
hook up vcr tv
  • Audio Players & Recorders
