20 Most Recent Insignia Solutions Original INSIGNIA TV remote control for NS-39D310NA15 NS-48D510NA15 NS-19E310NA15 NS-24D510NA15 NS-28D310NA15 NS-32D310NA15 NS-32D510NA15 NS-50D550NA15 NS-42D510NA15 NS-40D510NA15 NS-32D311NA15 NS-55D550NA15 NS-29D310NA15 NS-32D512NA15 NS-32D312NA15 Questions & Answers
I need a manual for this product. How can I get one?
Here is a link to the INSIGNIA NS-39D310NA15 manual: Insignia NS 39D310NA15 User Manual Good luck!
2/2/2016 5:01:14 AM • Insignia... • Answered on Feb 02, 2016
How can I get a manual for NS-40D510NA15
Insignia has the manuals for most of their products on the product page. Click on the Support/Downloads tab. For the NS-40D510NA15, see http://www.insigniaproducts.com/products/televisions/NS-40D510NA15.html . The direct link to the User's Guide (as a PDF) is http://www.insigniaproducts.com/cms/documents/manuals/NS-40D510NA15_14-1088_WEB_V3_ENG_Final_lr.pdf . There is additional documentation available and there is an HTML version of the user's guide as well. I hope this helps. Cindy Wells
2/2/2016 12:07:38 AM • Insignia... • Answered on Feb 02, 2016
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls. Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
11/29/2015 4:03:00 AM • Insignia... • Answered on Nov 29, 2015
How can i see the images on my TV ?
See the image. 25496312-5uwfly0ugywyfgzhf0xc2tde-3-2.jpg Gopakumar Gopalan Google
3/1/2015 1:29:36 PM • Insignia... • Answered on Mar 01, 2015
How do I run Auto Channel Search?
Refer its user manual for details.
2/24/2015 5:11:22 AM • Insignia... • Answered on Feb 24, 2015
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section. However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves. If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part: >Capacitance (uF): same as the original, or 10% higher if the original value is not available >Voltage: same or higher >Temperature: Maximum temperature should be same or higher >Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors. >Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation. >Endurance: Try to get 8000 hours or better. I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
1/2/2015 8:34:31 PM • Insignia... • Answered on Jan 02, 2015
2answers
My television will suddenly turn off every 4 minutes or so and when I turn it back on it will do it again. I need help to stop this please?
The most obvious reason is an overheating issue in the Power Supply board. There are other ideas here, but you need to take it to a television engineer to diagnose https://www.google.com/search?q=television+will+suddenly+turn+off+every+4+minutes ..
4/24/2024 6:22:38 AM • Televison &... • Answered 4 hours ago
Harwa Smart television. How to restore Apps, it doesn't want to open for Apps.
Check the internet connection. The television can't update if it can't see the internet. Resetting it breaks the previous settings. Just for fun, reboot the router as well and wait 15 minutes until all the lights come back on. Then reestablish the television connection to the router. Harwa is not a make we know here in North America. https://www.google.com/search?q=Harwa+Smart+television.+How+to+restore+Apps ..
4/23/2024 11:02:30 PM • Televison &... • Answered 11 hours ago
How to remove child lock from BELTEK TV?
general steps: Get the TV remote control and push the "Menu" button and select "Options". Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip". Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button. Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV. Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control. If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
4/22/2024 8:10:04 PM • Televison &... • Answered Yesterday
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps: Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly. Switch on your TV: Ensure your TV is turned on. Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice. Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted. Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list. Bed.-Anl. H2 Version1 (ruwido.com)
4/21/2024 7:58:23 PM • Televison &... • Answered 2 days ago
My ecco TV is on but the screen is black when flashing light I can see the picture tv model LH 32.
That sounds like it has a backlight fault. A good TV engineer can possibly repair that for you.
4/21/2024 2:31:53 PM • Televison &... • Answered 2 days ago
Tek L26D10. How to open the unlock the TV unlock code for Tek model L26D10?
Ask your parents. There is no easy way to defeat the parental lock.. https://www.google.com/search?q=Tek+model+L26D10+TV+unlock+code ..
4/21/2024 5:35:32 AM • Televison &... • Answered 3 days ago
6answers
Vistron remote codes for sky
TV maker is Palladium codes are 0560, 398, 391, 446
4/20/2024 8:49:55 PM • Televison &... • Answered 3 days ago
JVC KW-AV50 DVD receiver. None of the volume Up or Down buttons work JVC KW-AV50.
Try cleaning behind them with electronics switch cleaner spray, but it may be the whole module is faulty. https://www.google.com/search?q=jvc+kw+av50+volume+button+not+working ..
4/20/2024 6:31:28 PM • Televison &... • Answered 3 days ago
2012 troybiilt super pony transmission axel is trying to slide out how to fix it
The axles may have substantial amount of in/out play, 1/4 inch or more. Does the axle in question actually drive the wheel or does it freewheel?It's a typical differential so if you get both wheels off the ground and spin one wheel, the other wheel should rotate in the opposite direction.The axles are retained by the differential assembly (inside transmission) so if the axle is truly falling out, to fix it will require transmission be removed and opened. Probably not an economical repair unless you can DIY or replace with good used unit.
4/19/2024 9:41:16 PM • Televison &... • Answered on Apr 19, 2024
What is the sky remote code for a cello model c20234f-led ?
Turn on your Sky Box and TV. On your Sky Remote, press the TV button. Simultaneously press the Select and Red buttons until the red LED on your remote blinks twice. Enter one of the following 3-digit remote codes for Sky TV: 2274 2169 1874 1798 1872 1873 The light on the remote should flash twice. If it blinks only once, repeat the steps with the next code. Press the Standby button on your remote. If your television turns off, press the Select button to save the setting. Turn on the TV and press TV Guide; if the TV Guide list displays on the screen, the programming was successful. Remember that there are multiple versions of Sky Remote Controls available, so ensure you have the most recent version. If you encounter any issues with the 3-digit codes, you can also try using a 4-digit code. Here's how: Repeat steps 1 to 3. Enter the 4-digit Sky remote code for your TV brand. Press the Standby button. If your TV turns off, press Select to save your settings. Check if the TV Guide displays successfully on the screen. Sky TV Remote Control Codes
4/19/2024 8:32:21 PM • Televison &... • Answered on Apr 19, 2024
2answers
Harwa 32 Inch Led Television. How do I update my software on my Harwa 32 inch as my apps show it needs an update.
To update the software on your Harwa 32-inch TV, follow these steps: Check Other Solutions First: Before proceeding with a firmware update, ensure that you've tried other troubleshooting solutions. Sometimes issues can be resolved without updating the firmware. Gather Necessary Items: You'll need the following: A computer with an available USB port. A high-speed internet connection. A USB flash drive. Find Your TV Model Information: On your TV, navigate to the Help menu and select System Info. Write down your TV's model, revision, and firmware information. Download the Firmware Update: On your computer, visit the Insignia Products website at www.insigniaproducts.com. Click on Support & Service. Enter either NS-19D220NA16 or NS-19D220MX16 in the search box under Manual, Firmware, Drivers & Product Information. Follow the Firmware Installation Guide: Download the firmware update from the Insignia website. Copy the firmware file to a USB flash drive. Install the Update on Your TV: Plug the USB flash drive into the USB port on the side of your TV. Press the MENU button on your remote. Navigate to HELP and press ENTER. Highlight Update Firmware and press ENTER. Confirm that you want to update the TV firmware by selecting OK. Your TV will display a status screen while installing the update. Do not turn off your TV during this process. Once the update is complete, unplug the USB flash drive and press ENTER. Your TV will turn off and then back on to finalize the update. Rescan for Channels (if needed): If your channel list has been deleted, you'll need to scan for channels again. Refer to your TV's manual for instructions on how to do this. Remember: If you encounter a message saying the firmware file is incorrect, ensure you've downloaded the correct file for your specific model. If the update fails or your TV screen remains blank with a blinking red then blue power LED, turn off your TV, turn it back on, and run the upgrade again.
4/19/2024 7:23:41 PM • Televison &... • Answered on Apr 19, 2024
Need a new remote control for iheater ih1500--how much does it cost and can you ship it to me? model IH1500 Serial IHA080939250
Sorry, we do not supply anything. I would aproach the supplier or manufacture for advice and spares availability.
4/19/2024 3:13:01 PM • Televison &... • Answered on Apr 19, 2024
Sorry, but we do not supply parts. This is a website for advice on repairing items. You could try contacting the store you bought it from or contacting iheater directly.
4/19/2024 3:12:50 PM • Televison &... • Answered on Apr 19, 2024
Insignia Solutions Original INSIGNIA TV remote control for NS-39D310NA15 NS-48D510NA15 NS-19E310NA15 NS-24D510NA15 NS-28D310NA15 NS-32D310NA15 NS-32D510NA15 NS-50D550NA15 NS-42D510NA15 NS-40D510NA15 NS-32D311NA15 NS-55D550NA15 NS-29D310NA15 NS-32D512NA15 NS-32D312NA15  Logo
Popular Tags
6 questions posted
Top Insignia Solutions Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Insignia Solutions Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Solutions Televison & Video
Most Popular Question
need manual product get one
  • Televison & Video
