Acer NSK8458AN Keyboard Logo
Posted on Jul 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer aspire 8930T - german settings (QWERTZ) - reverse Q and @
Hello - when typing ALTR + 2 instead of @ (as signed on the keyboard) - a 2 in extension appears. @ ist only typed on screen when pressing ALTGR + Q; Keyboard settings are on GERMAN - also the Language settings; what is going wrong - have I to replace it (it's a new one with guarantee).. thank you
Anonymous
Level 2:
  • Expert 130 Answers
  • Posted on Jul 14, 2009
Anonymous
Expert
Level 2:
Answers
130
Questions
Helped
33591
Points
281
If you want it in English the do the following.
Start > Control pannel > Regional Options > Select the seconds tab > "Details" And select whihc keyboard language you want.
Good luck.
P.s. That was an example for XP not sure about Vista
German keyboard layout problem
The uses for mapping your keyboard are numerous, but remapping your keyboard's keys is not for the squeamish.
There are numerous software applications to map and remap a keyboard's keys.
The best part is that the software is free and easily downloadable via the Internet.
So, go ahead and swap those unused keys on your keyboard to suit your computing experience, and make your keyboard more effective without fear of damaging your computer
Place your mouse pointer over a key on the visual keyboard. Notice that the key is numbered.
To see what function the key is currently assigned to, allow your mouse pointer to hover over the key.
A pop-up displays what the key is attributed to.
Left-click the mouse pointer on a key you wish to change.
Click on Choose New Remapping from the drop-down menu.
Select Remap Key from the Control area on the interface.
You may also opt to disable or enable the key, and reset the default for this key.
Left-click Apply. Look at the list box at the top-left of the interface, labeled "Remapped keys currently in effect."
Ensure that the keyor keys you selected are listed in this list box.
Fix a mistake by resetting the defaults.
Click on the top button adjacent to the list box you just visited.
Pressing this button will remove all the changes to your keyboard mapping.
SharpKeys is a Registry hack that is used to make certain keys on a keyboard act like other keys.
http://www.randyrants.com/2008/12/sharpkeys_30.html
tip
When I try to type the ampersand ( @ ) I get the quotation ( " ) sign instead
PROBLEM: Some keyboard characters type incorrectly and are swapped. Most notably the Ampersand - @ and the Quote sign - "
RESOLUTION: The wrong country selection for the keyboard layout has been selected. An ENGLISH - UK keyboard with an ENGLISH - USA keyboard type selected or the reverse.
Go to CONTROL PANEL, REGIONAL AND LANGUAGE settings and select the correct keyboard for your system's country of origin.
on Apr 08, 2010 • Computers & Internet
2helpful
2answers
I was given an acer aspire one notebook but windows 7 appears to be in german how can i change this to english
The program disc loaded into this computer was in German
An English version is needed
This can not be changed by typing in anything with the German version loaded into it
Installing a brand new Aspire M3800 and made wrong settings
Press Start the Run and type intl.cpl
in windows 7 press Start and type intl.cpl in 'Search programs and files' bar
On the windows that opens go to
Keyboard and Languages tab
and press change keyboard
click add button if the new zealand isn't in installed services
on defult input language drop-down menu select new zealand
1helpful
Acer aspire one net book shift 2 responds as " not @ shift 3 responds as pound sign not #
keyboard was defaulted to US when operating system installed
Go to Contol Pannel-regional settings change keyboard setting to English.........I set then to Australian maybe theres a better setting for others
Barcode reader language
Concerning the Z issue you should select german keyboard from 123scan
Else you will have to program macro to substitute the caracters
2answers
My laptop went off by itself,i put it back on and the keyboard setting totally changed.now i have to push the function button while i type to get all the letters at the right corner which will be...
n Vista go to "Control Panel/Regional and Language Settings" and select the keyboard language Tab to choose language to suit your keyboard.
I think its "Control Panel/ Regional Settings" in XP. John
MY ACER A0A150 IS CONFUSED. WHEN I WANT TO TYPE " IT DISPLAYS @ .AND VICE VERSA. WHEN I TYPE THE POUND SIGN I GET # .ALSO WHEN I TYPE # I GET \ .I HAVE TRIED TO FIND OUT HOW TO CORRECT THE PROBLEM...
Hey,
it seems your keyboard is set to another language to change this setting. press start -> then control panel -> then Classic view (on the left side panel) -> now on the right find Regional and language options -> then select Keyboards and languages ( might be a little diffrent ) -> Change language or keyboards
Then finaly you should get text services and input languages (this might be diffrent since im using windows vista)
Now you need to set your default input language to the one you want to use, for example English or german for example. Click apply and OK. You can also click on the extra languages that you might see there that you don't need and then click on remove to remove them from the list.
Close the window with OK.
Problem should be solved, if not restart and make sure your correct language is set as default, and delete the extra ones if the problem persists.
Thanks and good luck.
Ekse
1helpful
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
