LG Optimus Black Smartphone Logo
A
Anonymous Posted on Oct 15, 2015
Keeps turning off. battery is 100% charged. never got wet
richie46
Level 3:
Top Expert:
  • LG Master 12,962 Answers
  • Posted on Oct 16, 2015
richie46
LG Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2946439
Points
58151
Your smart phone is a dead phone. If you got it under some sort of plan see if they will exchange it for you.
My 1989 yamaha 200 riva don't want to turn over n
Start by checking the battery. For a wet (lead acid) battery:
VOLTAGE (OCV) STATE OF CHARGE
12.8 100%
12.6 75%
12.3 50%
12.0 25%
11.8 0%
For an AGM battery:
VOLTAGE (OCV) STATE OF CHARGE of AGM Battery
12.7 V 100%
12.6 V 75%
12.3 V 50%
12.0 V 25%
11.8 V 0%
So all batteries are pretty much the same.
Then after seeing what surface voltage you have an recharging if low, the next step would be to get a load test done on the battery and clean and tighten the battery cable attachments at both ends of the cables. If it is not a problem here the next step would be to diagnose the starter and the starter system for which information as to exactly what happens when you activate the starer is necessary
Sep 09, 2014 • Motorcycles
Lattitude e5520 wouldn't charge
Ted try this once more:
1. turn off the machine.
2. keep pressing the off switch a little longer 3. remove the battery.
4. press the off button for say 15 seconds.
5. re-install battery after a few minutes.
6. connect charger to computer and see if it shows % charge.
7. when it shows 100%disconnect charger and see if the battery still shows 100% If it does you are now reset. IF not,will cross the bridge then.
As you your battery life of your notebook ? The main problem with laptops is often the battery , after a year of heavy use loses almost 50 % of the power . How can I prevent that ? Have you could keep a...
I have some tips to keep your laptop battery live longer
1.don't undercharging and overcharging,laptops battery can reach 100 degress Fahrenheit and such heat can damage your battery. slowly but sure
2.ideally,you should try to keep your battery charged from 20 percent to 80 percent. i know it's inconvenient to unplug the charger before it reach 100 percent,but try to keep it charged near 80 percent
3.try to charge your battery constanly,and unplug it when you think its almost fully charged,overcharged can heat your battery and damage it
4.keep your laptop as cool as possible,don't try to charge the battery when the computer is turned on,even if the battery is going to 0 and you still need to use it,just shut down the laptop first and charge it,at least until the battery is charged 20%,unplug the charger and turn it on
Well,there are many other tips to keep your battery alive,but i only have those 4,thanks for using fixya
and good luck with the tree-planting project,i love environment very much
1helpful
My Computer Kepps Turning off!
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
1helpful
I purchased lenovo z 570 laptop.clarification of regarding battery i am making 0 battery for every 15 days. (A) BATTERY is fully charged (100% ) , even though iam keeping plug in socket & using...
Not really, the older NiCad batteries get a memory effect if you keep charging from a half charged state, but modern Lithium batteries do not suffer from this problem.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.These rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
My laptop will not work on the battery and i need to keep it plugged in although the battery say 100% charged, why
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
My Samung P3 will no longer keep a charge. I can leave it on the charger all day, then turn it on and the display shows a half charge. After which, it will just shut off saying battery not charged. What...
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Truck won't start, new battery, lights keep flashing
Sometimes the new battery is not 100% charged. Put it on a charger or jump start the car, the alternator should then charge up the battery.
3answers
Phone turning off
My phone does that too randomly. It hasnt lately though and I truly never drop it much. I am having a problem now with my battery
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
