Where is the off /on button
Tips for a great answer:
- Answer the question.
Tell us some more! Your answer needs to include more details to help people.
You can't post answers that contain an email address.
Please enter a valid email address.
The email address entered is already associated to an account.Login to post
Please use English characters only.
My hp 6300 front panel lights are not working...how do i fix
Try below resets, one after the other if issue persits.
Power Drain :
Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
Press and hold the Power button for 60 seconds.
Connect the cable and turn ON the printer.
Partial Reset
Remove the power cable from back side of the printer while its ON.
Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
If printer turns OFF, press power button to turn it ON.
Semi-Full reset
Remove the ink cartridges.
Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
Insert the ink cartridges.
NVM Reset
Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards
Riztech
HP Office Jet All in One : Resetting Steps
Power Drain :
Connect the cable and turn ON the printer. Partial Reset
If printer turns OFF, press power button to turn it ON. Semi-Full reset
Insert the ink cartridges. NVM Reset
Insert the ink cartridges. Regards,
Rizwan
Ink system failure, error 0xc18a0001. happened suddenly, adviseme to turn it off, have turned it off, and same problem persist, it will not function a all.
Resetting the printer fixes most of 0x errors. Try next reset if the 1st one did not work.
Power Drain:
Riztech
On printer bling bling cannot do anything
Hi, Please try below resets one after the other if issue is not solved by 1st method.Power Drain :
Insert the ink cartridges. Regards Riztech
Scanner Failure
Cycle Power and try scanning again.
Warming Up
Power Drain :
Riztech
When I turn my hp g85 on,I get the following message:initializing,then a sound then press enter to allign cartridges then the printer flashes off &on and turned off by its self.
Power Drain :
Press and hold "Enter" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Riztech
MY HP OFFICEJET 6 310 ALL IN ONE INKJET PRINTER IS FLASHING RESET POWER
Please follow below resets.
Power Drain :
Riztech
I hooked the printer up and all the lights are blinking it says reset power...what do i do...
Try the below resetting steps
Power Drain :
Rizwan
Officejet 5610 All-In-One InkJet Printer: error 0xd0620130 reset power...
Please try the below resetting steps
Power Drain :
Rizwan
Worked yesterday, now will not turn on!
Try connecting the printer directly to wall outlet without surge protector.
If the problem exists reset the print, see below steps to reset it. Power Drain :
Riztech
