try to reset/configure the silent profile manually, in some phone silent profile mean only light no sound/vib/or tone. you can change it from manually configured (personalise in NOKIA)
User options Press FCN while on hook to change settings (* shows current, follow display instructions to set): Ring Type-select: Normal (for an audible ring) Vib/Norm (vibrates for five seconds, then rings) Vibrate (vibrates until answered) High Noise Mode-select: Normal (for most office environments) High (for moderate background noise) Severe (for extremely noisy conditions) Current IP address: may not be edited. Extension number: may not be present for some protocols. Additional options may be present
Have you had the wheel rebalanced? Also, you could swap it to the rear of the car. If the vibration goes to the back, it's a problem with the wheel/tire. If it stays, you have a suspension issue.
If it's the wheel/tire, check for a bend in the wheel, abnormal wear on the tire, proper tire pressure, and evidence of missing weights. Rebalance the wheel and if that doesn't do it, you'll need a new tire, possibly a new wheel if it's damaged.
Well, glad its working. Interestingly under profiles, I don't have an advanced settings and it seems like what I setup applies globally. Looks like your configuration might be different.
Hi, your vib motor probably has dirt or stray hair so its not spinning, or it has just seized.
Simply bring to a local repair shop for a cleaning - about $15, if thats no good have them replace the vibe motor, cost is about $25-40 including install.
If you can't find a shop to do it let me know, we do those all the time
