20 Most Recent
Samsung SCH-u540 Cellular Phone Questions & Answers
White screen! :'(
Remove the battery then wait 45 sec.put it back. Turn on again. Save your files to a laptop quickly. Do a reset factory. Reinstall.
Blocking numbers to my cel phone
sorry renosean there is a way. contact you provider and tell them that you would simply like them to deny phone numbers access of calling you. with some providers you can even redirect them to 1800numbers. bye
I can't delete an app from my ipad
delete Apps on iPad:
there are 2 different ways to delete an App:
1) t's easy to delete apps from the iPhone or iPad. Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner. that's it.
2) For devices running iOS 5 and later, there is also another way to do this is hidden in the Settings app, in the General tab, under: usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a certain delay if you have a lot of apps) that your on-board apps are listed in descending size order. That means: the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app and the size of the Documents & Data. Just below that, you'll have a Delete App button in red. At the very bottom, you'll see how much space is available on the device itself.
Deleting apps that take up too much space is helpful when you're trying to install new apps, You may even notice apps that have a lot of storage attached to them that you weren't even aware of before like internet radio apps that sync songs to your device to play during the time you're not connected to the internet.
-- however, there are some core apps belonging to the iOS system and cannot be deleted like 'clock', 'calendar', 'contacts' etc.
White screen
I have the same problem. I dropped it in water about 1 1/2 months ago. But it started working fine. One day i shut it off. and when i turned it back on the screen is white. I looked at the dot and its still white. It started working again but then I accidently dropped it and it messed up again. Anyway to fix it?
FREE UNLOCK CODE FOR SAMSUNG U540
Hi free unlock code are untrustable many times .I recommend you to visit
Unlock-zone.com here first you need to specify the network name to which your mobile is locked and the IMEI number of your mobile .Then at last they deliver you code to unlock your mobile.
