20 Most Recent
Doro DECT 540 Cordless Phone Questions & Answers
My phone is working but
working! presume u mean phone has dial tone and your able to dial out. Dial 17070 to verify your number. Possible u have crossed line. Hope this helps - BTscott
Doro 540R manual
Hi I have a manual do you still need one I can scan this one if you like. Allan.
Only bass set going extra hand set not working
This is because the extra handset might have not been registered with the base unit.The headset should be register to use the headset with that base unit.
To register the handset to base unit please follow the instruction:-
On registration the handset is allocated a handset number for use on the new base unit, the handset numbers are 1-5.
1. Press and hold
on the base unit until starts flashing. Registration mode will remain active for approximately 3 minutes.
2.Press and hold both
together until you hear a long beep.
3.Select the base unit you wish to register by pressing the corresponding number button 1-4.
4. When PIN is displayed, enter the units PIN number (0000 for this model).
5. If the registration is successful the handset will return to standby mode in a few seconds.
Thanx
I can receive a call but caller cannot hear my reply on Doro Phone easy duo cordless
double posted but now a not complete model told
a land line. posted o cell phones wrongly.
DORO PhoneEasy 100W Duo - cordless phone with caller ID?
or the model 110
or the model 115
we can not guess the model numbers
the the microphone is failing
did you get 2 phones in the kit new (as is common) and both fail.
is the battery still good.?
see this hole, , clean it carefully, of food or spittle. sludge.
that is the MIC.
