20 Most Recent
Doro 530 Twin Cordless Phone Questions & Answers
DORO NeoBio 10 Cordless Phone
The hand sets probably need to go through the 'registration' process with the base station. Look up the steps on how to do this in your manual.
One thing that the manual sometimes does not highlight clearly is that first you need to press and hold down a button on the main base station for a while until it beeps. Then you can go through the menu on the hand set to complete the registration process.
How to i change ringtone on doro 530
After searching the net for a 'FREE' manual, I decided to just rely on my own instincts as a technician. Scroll through the up and down buttons until you start to get a menu. Press 'OK' at the menu option you want and so on. It's fairly simple and intuitive. You'll stumble your way through til you get the logic behind it. Date and time are fairly simple.Hope this helps.J.
Doro 130 R
Go to http://www.doro.com.au select home phones then Support then Manuals Then you type in your model which should be on the back of the base unit.
Doro 540R Cordless
press and hold speaker button until p is dispayed on the hanset
press 5
current setting will be displayed
select by scrolling with left and right keys
press speaker button to save
Doro Home cordless phone not working
it sounds like you may not have any dial tone in the house. some phones have a light come on when the phone isn't recieving dial tone.[in your case the anntena] you can try plugging a corded phone into different jacks in the house.there maybe a box [called a nid] on the outside or in the basement/garage where you can plug a phone directly into it bypassing all the jacks in the house [there could be a problem in the house] if still no dial tone ,call your phone company
wg
I can receive a call but caller cannot hear my reply on Doro Phone easy duo cordless
double posted but now a not complete model told
a land line. posted o cell phones wrongly.
DORO PhoneEasy 100W Duo - cordless phone with caller ID?
or the model 110
or the model 115
we can not guess the model numbers
the the microphone is failing
did you get 2 phones in the kit new (as is common) and both fail.
is the battery still good.?
see this hole, , clean it carefully, of food or spittle. sludge.
that is the MIC.
