E000 the heater fails to heat
E001 there is an abnormal rise in temperature
E002 there is an error in the rise in temperature
E003 there is an error in the rise in temperature
E004 there is an error in the IH power supply/IH control mechanism
E005 there is no fixing web/there is an error in the detection of web solenoid connection
E010 there is a feed motor error
E012 there is a drum motor error
E013 the waste toner pipe is clogged
E014 there is a fixing motor error
E020 there is no toner in the developing assembly; there is an error in the detection of
developing assembly toner sensor connection; there is an error in the detection of
developing hopper toner sensor connection
E025 there is an error in the detection of toner feed motor over-current, there is an error in the
detection of toner bottle motor over-current, there is an error in the detection of toner
bottle motor connection
E032 the counter of the NE controller has malfunctioned
E061 there is a potential control error/there is an APC error
E100 there is a BD error
E110 there is a polygon motor error
E121 there is a controller cooling error
E196 the EEPROM is faulty
E202 there is an HP error
E225 there is an error in the intensity of light
E227 there is an error in the power supply (24 V)
E240 there is an error in the communication between the main controller PCB and the DC
controller PCB
Replace the sensor motor.Make sure to test before replacing it
