If you are experiencing this problem, continue as normal to print your clock then choose preferences and ensure your printer settings are ok and that it is set to print to the dvd/cd tray, then proceed to print your clock.
If you are still experiencing problems Try Solution 2..
Instead of changing your printer settings through Clock Designer, change your default printer settings. Go to the control panel in windows and open the printers section. Find the printer you are using (Actual screen shots will vary depending on your version of windows and printer)
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For
Epson Printer Support
