There is a possibility that your key fob might lost the programming. I suggest that you re-program your key fob, follow the next steps to re-program it.
Instructions
Read more : http://www.ehow.com/how_7446180_program-key-fob-kia-optima.html
SOURCE: 2004 Kia Optima - Key Fob
you need to reprogram it ok this is what you do turn the key to the on position but do not crank it take the clicker and aim it at the lower dash driver side of sterring wheel press the lock button a few times then turn off key remove key and try clicker this should fix it
SOURCE: renault key fob doesnt work
Hi.
I have a clio II, 2001, i have the same problem and i fixed it.
Don't know if will work for you but here it goes:
1 - no key in ingnition
2 - press the unlock button in console off the car for about 10 seconds(dont let go)
3 - it should work the central doors one time and then 2 times( hear)
4 - press the remote a few times until it starts working
It worked for me hope the same for you.
Please tell me if it worked and pass the message.
Good luck
SOURCE: how do you re-link the key fob to the car after
Try this,,turn the key on ,wait 10 minutes,then turn the key off,then right back on,do this three times,a total of 30 minutes,this should reset the key fob,if this is the problem.
SOURCE: 1997 C200 Key Fob Failure
Max, how did you fix your problem? The same thing happened to me today and I have to call the dealership I assume. Thanks, Judy
