wonder if the machine requires: 1-nnn-nnn-nnnn (without -) format of the recipient's fax no. (does your phone system require a prefix no. to call number outside of the bldg.?)
The orignal ink cartridges supplied with these machines are fairly low capacity. You can get XL versions which contain 2-3 times as much ink. If you are using refilled cartridges, you may find the Fax module can not tolerate refills. There is a way to reset the machine to ignore the ink level counter for the printer/copier functions, but the Fax module addresses the cartridges diferently for some reason.
Sending Faxes Automatic Transmission 1 Place the original face down in the ADF. 2 Enter the fax number using One Touch (FAX models only), Speed Dial, Search or the dial pad. 3 Press Fax Start .
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
