20 Most Recent Brother IntelliFax-2820 Laser Fax Questions & Answers
Everything seems to indicate a dirty 'corona wire'. This seems to be the most common cause of vertical white lines running the length of a page when copying/sending. Below is a link to the User's guide for your machine with instructions for cleaning the corona and other care when using your fax machine. Best of luck.
Greg
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
Brother... | Answered on Aug 23, 2019
Press Menu * 2864 (within 2 seconds) [MAINTENANCE MODE] press 01 (INITIALIZE)
Brother... | Answered on Mar 28, 2017
Hi Make sure the paper tray (cassette) is not missing the small separation pad with the spring. It is part of the paper cassette. the roller may be worn so cleaning it might not help. Lawrence
Brother... | Answered on Oct 25, 2016
you can clean with alcohol and a q-tip, sounds like you have a bad toner cart. or fusing unit is bad
Brother... | Answered on Jan 08, 2016
Get some paper dust cleaning paper from a an office supply company and run a sheet thru it a few times. It's sticky and will clean the rollers.
Brother... | Answered on Jun 20, 2015
1. Maybe a Paper Jam below the drum
2. A lever on the inner back cover is missplaced
Brother... | Answered on Mar 16, 2015
Is it a name brand cartridge or a cheaper knock off? Some printers won't recognize a different cartridge even if it is the same size and shape. They make them that way so you have to buy the makers cartridge.
Brother... | Answered on Dec 03, 2014
What do you mean ?
Brother... | Answered on Nov 29, 2014
make sure the receive mode is Fax or Fax/Telephone and it will work
Brother IntelliFax-2820 Laser Fax Logo
993 questions posted
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
error message close back cover
  • Office Equipment & Supplies
