When I turn the knob for changing the needle position, the needle position does not change.
Customer Support ,,,,,
SOURCE: Needle wont go up or down
If the Handwheel (big knob) is moving but the needle is not moving, you need to engage the clutch ........depending on the model
- push handwheel in to engage, pull out to disengage
or
- if there is a smaller wheel inside the handwheel, tighten to engage, loosen to release.
BUT if all is jammed........
Check for threads that are jamming the motion of the hook around where the bobbin case is
If your bobbin goes in from the top, remove the needleplate and bobbincase remove thread jams by gently rocking handwheel back and forth until released.
Clean around the hook race with a rag moistened with methylated spirit, surgical spirit or similar, then reassemble.
If front loading, open the door for bobbin case area, release 2 retaining clips holding the collar on (take note of the position/orientation for when you re-assemble....even take a digi photo to refer to !?!).....
......then just do jam removal & clean out in much the same way as for the top loader.
In all cases, don't force too much or be too brutal, gentle and patient works best, try to judge where the jam is caught and work with it slowly......you may need to cut jammed threads, just ensure all are removed before you re-assemble.
SOURCE: singer 3116 - change the needle
I'm giving you a direct link to the Manual on page 82 of which is explained the procedure of removing the needles so you can attach new ones the same way...
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Lemme know if it helps :-)
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
SOURCE: The machine needle is no longer in the correct position
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
SOURCE: my singer curvy 8780 has
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Where's the answer
