Assuming you have used a Dell approved ink cartridge the problem is most likely just a dirty print head. If you haven't printed for a while (which can be only a week or so in hot places) you may have to run the cleaning process 5-10 times or more before you start to see marks on the paper. This is typical of all ink jets that are not used regularly. If you can not get it to print or it will not get good enough to print you can resort to manually cleaning the print head with a qtip dipped in viniger which disolves most inkjet inks. It won't take very much to clean and it will print like new.
The ink cartridge carrier moves and stops at the loading
position unless the printer is busy.
