SOURCE: machine error 48 or init unable 48
There are several issues that pertain to this code, including a service update. If your printer is still under warranty – visit your local ASC, find one here, this issue is covered! First off, the Service Update, the encoder strip needs to be cleaned with a lint free cloth. The encoder strip is responsible for relaying the position of the print head to the main pcb. If the encoder strip gets dirty, many different problems can occur. The encoder strip is exposed, which allows grease, paper dust, finger prints, ink, etc. to get onto the encoder strip. (The white strip when you open the scanner cover)
If the machine still errors, the encoder strip needs to be replaced – Part Number LS4467001
If the machine still errors, replace the carriage PCB assembly – Part Number LS6543001
If the machine still errors, replace the Printhead – Part Number LK3211001
If the machine still errors, replace the Main PCB assembly – Part Number LT0284011
THANK YOU FOR USING FIXYA! – DON’T FORGET TO RATE OUR SERVICE!
SOURCE: how to do the clean
Hi Good day!! try this method
- Machine off
Switch on the machine while holding down the "menu"button until all the
leds are flashing on/off. Now you are in "maintenance" mode.
- press 80
- press the "mono start" button several times until you see "purge: xxxx"
- press "2783" in order to reset the purge counter. You will see: "purge:0000"
- press "99" to exit the maintenance mode
Now
you are able to print again, but actually your ink absorber box is now
full with ink. Ink flooding can happen if you don't replace this ink
box!
Don't forget to vote thanks!!!!
SOURCE: Brother DCP-165C gives error print
The error message "Print Unable 46" is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Print Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
